Hahaha talking nonce bloody hell watch the typos guys
Hey Marty that was a mad ride home. There was a load of protesters or something outside Parliament, I gave them a wake up call with my exhaust while sitting at the lights outside the House of Lords. I got a right dirty look from Plod I think I must of blocked out the noise form this protesters megaphone thingy. Bloody cylists are riding like they have a death wish in London today
Anyway folks here are some picks of my fork lowers and Swingarm painted.
- agentpineapple
hi carl good job on the forks and swinging arm
what sort of paint did you use
I used calliper spray so should be pretty tough, chemical resistant and wot not. The pics don't do it justice, It's a bit like have both pearlecent and a metallic in one paint. You can see the specs in the pics, well, they are like glitter when the light hit's them.
Expensive paint but very good quality and easy to use. The nozzle on the can is superb as it spreads the spray evenly in a horizontal line. It's mixed up and then put in the cans.
http://www.ebay.co.uk/itm/270959388629? ... 1423.l2649
Would you like to paint mine Carl? Pretty please
It's really not that difficult to spray. The hard work is in all the prep. The calliper paint say's it does not require a primer, but I first gave them a coat of Acid etch primer, a coat of regular primer. I was then not 100% happy with the finish as it was still a bit rough in places, so I gave some spray putty primer a go, which by the way I would not buy again. I wet n dry (wet sand to those over the pond ) between al the coats and the final rub down was with 600 grade wet n dry. Get it as smooth as glass beforehand and then the top coat will look good.
If I was more local to you I probably would do it for you, but I would get you to do the prep first. with a little help from me. Lets see how the paint holds up to stones and stuff. I will leave it at least a week before I start on the internals and fitting them to the bike. The longer it is left the better as the paint should be rock hard by then.
Here's another pic that shows the finish a little better
thanks for the info
i was leaving them original but after seeing yours i might just cross over to the dark side
Have the forks been apart before?cybercarl wrote: I wasn't intending on changing the bushes as they are not cheap, but I guess I will see when I get to see what state the internals are in. My bike has only done just over 8500, not that it looks like it so I'm hoping they not in too bad a condition. But saying that the forks have bottomed out a couple a times with me so we'll see.
Using the stanchion against the lower like a slide hammer means that one slider is being bashed against the other, I'd recommend new bushes every time.
Cost isn't much, about 14 pounds each leg.
Forks have not been apart before as far as I know and definitely not been apart in the time I have had the bike. If the bushes are only £30 then I will get some but I could have sworn I saw bush kits IIRC on ebay that where around £70-£80 mark. I remember thinking, sh1t that's expensive. I shall have to re-investigate.
Silvers for uppers and M+P for lowers, or is it the other way round- look them up, they're not too bad, mate.cybercarl wrote:Forks have not been apart before as far as I know and definitely not been apart in the time I have had the bike. If the bushes are only £30 then I will get some but I could have sworn I saw bush kits IIRC on ebay that where around £70-£80 mark. I remember thinking, sh1t that's expensive. I shall have to re-investigate.
Or just ebay it.
Yeh I just checked the bay and it's a complete rebuild kit that cost £80 There no bushes on their own for sale there so I shall check wemoto out as well as silvers. What's a good brand fork oil to get Tony. I'm going to use 7.5W.
Yep the eBay ones are over priced . They ds or weemoto
I rebuilt a set of forks yesterday, got the bits from wemoto, they charge about £30 for a set of sliders, I would not agree with the 'change them every time' comment thought, yes you whack them together to part the forks, but they are big thick bits of copper. Mine took some right hammering to get apart but the bushes are mint. I didn't bother to buy them as its a second set of forks, so thought I would just stop and order them if needed.
It's much easier to damage them knocking the top bush back into the slider without damaging it, and that applies to a new bush anyway. Wear is the issue, if there is any slop they need changing.
My forks turned up from Lee yesterday, very well packed! good job! Started tinkering, not planning on doing the job yesterday afternoon, and 3hrs later I had a pair of rebuilt forks and had sprayed the lowers.
Much easier than other forks I have done. The bottom bolts came straight out, not like some where you need a special tool to lock the internals.
Going to change them over today, then I will be able to go for a proper ride for the first time!
It's the Teflon coating that wares and gets damaged .
It's hard to tell just by looking at them you need to go by feel
