Geeman wrote: ↑Wed Oct 17, 2018 6:16 pm
Hi...how does work...disconnect earth from rectifier and run straight to battery. Thinking of fitting a small volt/charging gauge to keep my eye on it...what do you think...cheers again.
Actually do both the earth and charge wire.
at the RR plug, snip the red and green wire about 20~30 mm from the connector, add wire extending them to the battery. Put a ring terminal on the green (earth) wire and connect directly to the battery.
On the red wire splice in a sealed ATO fuse holder and then a ring terminal and connect it to the battery or better add two more ring terminals and use a Marine rated 25 amp circuit breaker.
The VTR has a 21 amp max output from the stator so use a 25 amp fuse if going the fuse route (i don't use fuses any more, no longer offer that option, the breakers are a better option in my opinion). Wiring the RR output directly to the battery, bypassing the old wiring will improve charge voltage.
That said........ dont do it.....LOL, if your going to spend the time and materials, add a FH012 or FH020 MOSFET RR and the correct connectors which are a sealed type by Furukawa
- 18470d1427921158-installing-r-r-old-wires[1].jpg (54.03 KiB) Viewed 3784 times
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
