Duffy's Streetfighter Project
Re: Duffy's Streetfighter Project
Took a few photos before. Used wd40 but needs more work. Front cylinder has flaky paint hence the post for engine paint tips :)
Bit of an update: Engine before clean/de grease.
De Greased & Masked up:
Sprayed with heat resistant Graphite Grey :
I will paint the engine cases and rocker cover gloss black when the engine is in the frame as a rolling chassis
But that may take a while :lol: :lol: :lol:
looking really good ian.... :thumbup:
Cheers Marty, took me a while though, but pleased with it so far :thumbup:
masking up takes a while....... :roll:
good work Duffy.
I tried to colour match the silver grey so I didn't need to do the whole engine to fix a few areas of corrosion. I didn't get a perfect match, but once its in the bike you cant tell so its good enough, but I still know its bodged. I wish I had done it like you have and done the whole engine
Look very nice big boy . When you popping round to do mine ?
Watch out he's flirting again.
All the hard work is worth it for the feel good factor of seeing it done properly. :thumbup: What product did you use to paint it?
E-Tech Engineering XHT Xtremely High Temperature Paint
http://www.demon-tweeks.co.uk/performan ... ture-paint
Wicky wrote:E-Tech Engineering XHT Xtremely High Temperature Paint
Yep that's the stuff Wicky, has a satin type finish. My mate has just got a CB 650 F and his engine is a similar colour in a black frame and I liked the look of it, so this was the closest I could find. :thumbup:
lloydie wrote:Look very nice big boy . When you popping round to do mine ?
It's spray paint Lloydie, not lube :lol: :lol: :lol:
AMCQ46 wrote:good work Duffy.
I know what you mean Al but it's a pain if your just touching up, but I made the effort as its a total re build, so glad it did it as the flaking paint would have bugged me in the long run :thumbup:
bigtwinthing
Post by bigtwinthing »
that is looking great.
That is looking very good :clap: keep up the good work Duffy :thumbup:
Started to fit new linkage bearings today, got them all out but the realised I could only find 2 roller bearings, so had to order the other two :thumbdown:
Taped up the wiring loom and cleaned up all the connector blocks.
Sat the frame on the engine ready to fit, but noticed im the centre bolt is missing/lost in the Duff cave :crazy:
But it's still good progress, even if it's a bit long winded :thumbup:
keep at it mate, it should be stunning when it's finished.... :thumbup:
when I get back, i'll pop round with those mixture screws and your exhaust hangers, if I have a spare bolt i'll bring that as well.
Cheers Marty, sounds like a plan dude :thumbup:
