Project Blue Belle
Re: Project Blue Belle
StormyRob wrote:
agentpineapple wrote:Asv levers are some of the best, so much better feel compared to standard. and much more adjustability. the frame paint will take several weeks to properly harden, the time of year doesn't help, get that central heating cranked up.... :thumbup:
There is a woman in the house mate so the heat is never off!
Ain't that the truth!!!!
Package on way matey :thumbup: I will pm you.
Even when the woman goes out for the day she sill leaves the fecking heating on ! It must be 200'c in here
StormyRob
Post by StormyRob »
lloydie wrote:Even when the woman goes out for the day she sill leaves the fecking heating on ! It must be 200'c in here
My wife just to be terrible. Over the last few years she has had to realise heat requires money and she has gradually become a little more sensible! Still like a sauna half the time!
SKMXL
Post by SKMXL »
In our house I have a heating system called Danfoss living which I can control all heating from my mobile. In your case that could come in handy! :clap: :biggrin
Drive safe!
StormyRob
Post by StormyRob »
Decided to give the starter motor a go. Thankfully using the write-up from marty and some guidance from the man himself I have realised it is absolutely fine inside with no breakages whatsoever.
I do not know how bad everyone else's is but the outside is horribly corroded on mine and it needed a good clean which I also started this evening but then the missus told me I was probably pissing the neighbours off with the sound of the drill so it will be finished off tomorrow.
Having taken a little advice I may actually just cover it with hammerite to give some protection.
First time using Tapatalk so I hope this works. Seemed a lot easier to upload pictures!
Sent from my HTC One_M8 using Tapatalk
Jeeze! Looks like you were lucky to remove the headers judging by the corrosion around there.
Starter motor looks great inside and I can see the elbow grease is paying off on the polished bits. I've often toyed with the idea of polishing the end caps and painting the central can. But meh. Already done enough of that until the next overhaul.
P.s Tapatalk is wonderful! I still don't know how to post a pic on the laptop :crazy:
StormyRob
Post by StormyRob »
I have no idea how I got the header nuts off either!
Is bad under there. The oil filter was a nightmaret too but is now off. Will be ordering engine paint soon so underneath will hopefully look a lot better
great work rob, you are bringing that bike back to life, don't forget a big dollop of grease under the rubber boot that protects the main power lead/bolt on the starter, it's help the fight against corrosion. I doubt the starter motor could have been put in a worse place. glad to see you managed to free it from the engine, how big was the hammer..... :lol:
Last edited by agentpineapple on Tue Jan 05, 2016 4:34 pm, edited 1 time in total.
StormyRob
Post by StormyRob »
It was an absolute b***ard to take off. I thought I was doing something wrong initially! Normal hammer...Big bit of wood...thump thump thump
Thump thump thump......you get the picture!
Another job worth doing, good man :clap:
StormyRob
Post by StormyRob »
It a cleaned up Ok. Not fantastic by any means but much better than it was. Just gonna cover in hammerite and I am doneImage
Blue One
StormyRob
Post by StormyRob »
Blue One
bazza696
Post by bazza696 »
Its a shame they don't do a cover similar to what's on the CBF, its oil filter has a plastic cover to stop all the crud getting on it.
StormyRob wrote:Image
Blue One
looks loads better mate.... :thumbup:
StormyRob
Post by StormyRob »
Still needs to dry but I'm not fussed about that as it is going to be well hidden!
Thanks mate
