Yeah it will do that, the idea is that you break the weld. You could try using a bit of wood or something that is big enough to cove the baffle spout but small enough to to fit in the outer/larger spout, so that you can hammer it in a bit further. There is a risk that you wont then be able to reach it to pull it out so be careful.callam_nffc wrote:Its at the point where it just moves back further if I hit it with a hammer
Think I'm going to try and get some sort of half inch chisel that's like ten inches long and bash it out (ooh er)
I know the 'push pull as fast as you can' thing works because its how I did mine.
You said earlier that it was free & turning 360*. If you have room shine a torch down & see if in breaking it you have made a kind of key way. i.e. its broken but has a chunk on one bit. If so you will need to turn it to line it up & then remove.
Persevere it is worth it.
