sirch345 wrote:
It sounds like that plan should work well, building a box for that area is something I hadn't thought of. I'm guessing you'll still need to fit a battery box inside the main box to hold it from moving around.
I'm not too sure about that box idea yet Chris, I'm over thinking too many things tbh..
I've been doing bits, but it doesn't look like much tbh.
A quick run through is that.. I started looking into a lower foot peg idea that I'd been thinking up, I gathered up all the bits but I needed to weld up the frame so I could sit on it to get a better idea of what was what.
So I had to make the decision about the subframe. After looking at many different takes of sub frames, I decided to run with the original idea. It will be hidden anyway so it is no biggie if I do change my mind later.
The bike was disassembled & the main spine welded in along with the subframe supports. There will be more reinforcing added later, but this will do for now & will allow some more progress in other areas.
Another issue that's on it's way to being sorted is the fueling.
I've done a lot of reading about setting up Weber dcoe's on Harleys & because the Vtr is gravity fed I needed to get my hands on a high flow fuel tap to avoid fitting a fuel pump.
Pingel fuel taps were recommended, so Pingel it had to be.
Here's a comparison.
The bike has again been assembled & I've worked out where my legs going to get cooked & had a little play with some protective guards.
The mounts are 50mm Mikalor clamps with 6mm threaded tubing welded to them & the covers are 70mm guttering tubing.
I doubt they'll cope with the heat but it is just a mock up atm.
Another little job is the silencer mount. This was an ugly piece of 25mm mild steel box, this is what I've come up with. I was going to use round threaded tube but the wall thickness was too thin. I had to run a tap down these to clean after welding on 70 amps. Small strong & functional.
It needs a support from the subframe but I have to decide about what I'm going to do with the electric/ subframe box.
Here's a mock-up using mild steel plate. It's quite heavy, not ideal but the subframe would be really strong side ways. Imagine if the bike falls over on the exhausts, it might save the rear from twisting. Over thinking comes to mind
