TaxiDriver wrote: Tue May 10, 2022 6:24 pm
sirch345 wrote: Mon May 09, 2022 7:58 pm
TaxiDriver wrote: Sun May 08, 2022 6:41 pm Knocked up a carbon reservoir bracket for the Brembo MCS master cylinder....
Able to use original lines thanks to this nifty Hel adapter..........
Nice neat job with the carbon fibre bracket :clap:
What's the verdict on the Brembo master cylinder :?:
Don't know yet Chris, only just fitted it and new pads going in so after bleed up its on the the rear linkage and the likes.
Might even fit a rear thumb brake,not decided yet,full write up when ready....
No problem, I look forward to hearing from you once the work has been done and you've had time to bed the pads in and get a feel of the new mods :thumbup:
Thanks for your reply,
Pulled the big girls clutch plates out and replaced them :eek2 . and done the oil and filter again but this time with motul oil . back to what i know works :thumbup:
Retest on Nue Red. Just stuck me bigger plate on. Job done.
All good for another year.
It's started raing here now so the bits I was gonna do are being put off till tomorrow or Friday whatever.... :lol:
MacV2 wrote: Wed May 11, 2022 2:06 pm Retest on Nue Red. Just stuck me bigger plate on. Job done.
You can velcro it over the small one for MOT's. No-one expects the big ones to stay on for long, once you get your ticket.
Stick the red reflector on the big one as well, and you can't forget that come MOT time.
fabiostar wrote: Tue May 10, 2022 8:38 pm Pulled the big girls clutch plates out and replaced them :eek2 . and done the oil and filter again but this time with motul oil . back to what i know works :thumbup:
That was quick :thumbup:
Always good to get the mot out of the way for another year :thumbup:
How are you finding the OEM clip-on handlebars on Nue Red compared to the Renthal handlebar conversion Mac :?:
sirch345 wrote: Wed May 11, 2022 7:59 pm
had to be quick, its NW200 week so wana get a scoot up :clap: :clap:
fabiostar wrote: Wed May 11, 2022 8:07 pm
Ah, that makes sense :thumbup:
sirch345 wrote: Wed May 11, 2022 8:01 pm
Still not 100% convinced on the flat bars TBH the only big difference I get from swapping between the two is your more up in the wind on the flat bars...
Spoilt for choice I guess ! If I was only riding the flat bar version it would be differnt...
I'm on a longer run next week sometime TBA see how it goes.
Few bits on Nue Red, put the smaller plate back on, did a bit of wire tidying on the left hand front indi whilst the fairing was off to put the LED H/L back in post MOT. :lol: :lol:
Pulled the pads from the front calliper to try & get the number off them to order some more... SBS 566HS apparently...
ItsaKeeper
Post by ItsaKeeper »
Ordered a reflector to stick on the numberplate in prep for MOT next week, thanks to reading this thread :thumbup:
MacV2 wrote: Thu May 12, 2022 7:54 am
Good to hear your views Mac :thumbup:
It'll be interesting to see if you stick with the Renthal flat bar conversion, or swap them back to the OEM clip-ons. Or in your case keep both :D
sirch345 wrote: Thu May 12, 2022 8:45 pm
Most likley... :lol: :lol:
MacV2 wrote: Thu May 12, 2022 10:09 pm
:clap: :lol:
rollingthunderx2
Post by rollingthunderx2 »
Nothing arrived so far.
I have 8 and 7 mm studs here .
