Page 1278 of 1502
Posted: Sat Sep 28, 2019 9:20 pm
by Duffy1964
Good man
Posted: Sun Sep 29, 2019 4:17 pm
by mik_str
Dropped the bike off at the dealer`s yesterday to have the countershaft (one driving/holding the drive sprocket) replaced. It seems it was slightly bent (could have been from a brain-dead tech at another dealership who drastically overtightened the chain a couple years back while servicing soemthing else, or perhaps from the broken chain a couple months back, when it got wedged between the sprocket and swingarm pivot). It sucks (money-wise) but then the original bearing (which is pressed on the shaft, the shaft and bearing being sold as a unit) had 260,000 km on it so replacing it may be a good move in the long run. As the engine will have to be pulled, I am getting the valves (and cam chain tension) adjusted at the same time, as well as having the shock serviced, linkage greased and exhaust re-wrapped. Given it`s a slow time of year for the shop, I should get it back rather quickly, in time to get a few more rides in before Old Man Winter rolls in. I hope/expect the bike to be a bit smoother after the shaft replacement...
Posted: Tue Oct 01, 2019 7:08 pm
by Pete.L
Fingers crossed that you can still get out on it and at least test it after all the major work.
It was still warm in Toronto when I left on Friday. Hopefully it’ll stick around a little longer
Posted: Tue Oct 01, 2019 7:57 pm
by fabiostar
mik_str wrote: ↑Sun Sep 29, 2019 4:17 pm Dropped the bike off at the dealer`s yesterday to have the countershaft (one driving/holding the drive sprocket) replaced. It seems it was slightly bent (could have been from a brain-dead tech at another dealership who drastically overtightened the chain a couple years back while servicing soemthing else, or perhaps from the broken chain a couple months back, when it got wedged between the sprocket and swingarm pivot). It sucks (money-wise) but then the original bearing (which is pressed on the shaft, the shaft and bearing being sold as a unit) had 260,000 km on it so replacing it may be a good move in the long run. As the engine will have to be pulled, I am getting the valves (and cam chain tension) adjusted at the same time, as well as having the shock serviced, linkage greased and exhaust re-wrapped. Given it`s a slow time of year for the shop, I should get it back rather quickly, in time to get a few more rides in before Old Man Winter rolls in. I hope/expect the bike to be a bit smoother after the shaft replacement...
heres hoping alls well :thumbup:
Posted: Tue Oct 01, 2019 11:38 pm
by mik_str
thanks guys. Hopefully I will get it back by week's end... no snow here yet, lol (though Calgary, in Western Canada, got a freak storm which dumped over 30 cm)
Posted: Fri Oct 04, 2019 6:05 pm
by Commando77
Completed tyre change and fitting a new rear was a breeze compared to removing it😬. None of the Internet help was any use until I wedged the beads in the rim centre with offcuts of wood. Only then could I spoon it off. Front is half scrubbed in and looks like it's dry enough Saturday to do the rear...
Posted: Fri Oct 04, 2019 10:35 pm
by sirch345
I agree that does sound like a good plan to get it replaced now Micky.
It would be good if you can get it back in time for a test ride this year, hopefully you can :thumbup:
Posted: Sun Oct 06, 2019 7:45 am
by agentpineapple
Have my a good going over yesterday. Fairings off. Checking everything. Topping up the coolant. Greasing the starter motor terminal. Also fixed my gpi. It stopped working a month ago. Traced all the wiring until I found a broken wire. All fixed now. Painted the mirrors. Fairings back on and polished. Just need to check the tyre pressures and I'm off out for a ride.
Posted: Sun Oct 06, 2019 12:18 pm
by sirch345
agentpineapple wrote: ↑Sun Oct 06, 2019 7:45 am Have my a good going over yesterday. Fairings off. Checking everything. Topping up the coolant. Greasing the starter motor terminal. Also fixed my gpi. It stopped working a month ago. Traced all the wiring until I found a broken wire. All fixed now. Painted the mirrors. Fairings back on and polished. Just need to check the tyre pressures and I'm off out for a ride.
Are you abroad or back in the UK Marty :?:
Posted: Sun Oct 06, 2019 7:48 pm
by agentpineapple
sirch345 wrote: ↑Sun Oct 06, 2019 12:18 pm
still living abroad chris...... :thumbup:
Posted: Sun Oct 06, 2019 10:35 pm
by sirch345
agentpineapple wrote: ↑Sun Oct 06, 2019 7:48 pm
:thumbup: Good for you Marty, you probably have a better chance of more settled weather :wink:
Although I got a ride-out in today with good dry sunny conditions :D
Not bad for October, temp around 16C,
Posted: Mon Oct 07, 2019 5:40 pm
by agentpineapple
sirch345 wrote: ↑Sun Oct 06, 2019 10:35 pm
Only 27 and sunny here today mate. I'm blessed with great weather and fantastic roads. Oh and cheap fuel. Cheap beer. Cheap food lol
Glad to hear that you got a ride in today. Not long before winter hibernation up there mate
Posted: Mon Oct 07, 2019 7:38 pm
by fabiostar
nothing more than taking the long way to the garage for fuel :thumbup:
Posted: Mon Oct 07, 2019 9:09 pm
by sirch345
agentpineapple wrote: ↑Mon Oct 07, 2019 5:40 pm
Excellent Marty :thumbup:
Enjoy it mate, all of that sounds ideal :D
Posted: Wed Oct 09, 2019 3:40 pm
by MacV2
Whipped the fairing off to check/replace the bulbs in the clocks...Sadly it's getting dark on me way in to work in the mornings & I seem to be missing any illumination in the clocks...
Duff bulb in speedo so replaced with an LED...
Checked the oil, kicked the tyres & tightend, clean & lube the chain...
