Page 1123 of 1503
Posted: Mon Apr 17, 2017 9:03 am
by redpig
[quote="agentpineapple"]had a lovely ride today. started at 8am, it was still a tad chilly, but sod it, I set off for the coast. once there I chilled out and took a few pics.
then I headed back through the mountains to Gandesa. a quick splash n dash at the petrol stn and it was off to Mequinenza via Caspe. once there I stopped for a coffee overlooking the river.
then a spirited ride home. although I did stop at my local petrol stn to wash the bike and have another coffee with a birthday custard filled donut...
The beach is a bit empty, I'd have been in havin a paddle with me trousers rolled up a hankey on me head and ice cream stains down me vest.
Posted: Mon Apr 17, 2017 10:36 am
by bigtwinthing
sold the Old CBF Gel Seats for £180 and the single seat cowl for £25.
I have just to sell some leathers and i am done.
Posted: Mon Apr 17, 2017 12:10 pm
by OtterSmacker
Checked and added air to the tyres. Removed my rear hugger as I've noticed it's broken
Posted: Wed Apr 19, 2017 9:46 pm
by uk13iker
New pads and bled the brakes lots of air in system and the fluid was black no wonder my brakes boiled on track. Respray and forks painted is next job.
Posted: Thu Apr 20, 2017 11:01 am
by fabiostar
new rear wheel bearing fitted after a close call
Posted: Thu Apr 20, 2017 2:53 pm
by podman
Mine isnt far off that, im guessing its never been changed, on the cards for changing as soon as I can..
Changed Mrs P's chunky aftermarket grips and bling bar ends for OE grips and bar ends, the aftermarket grips and ends where catching and causing the throttle to stick, it was like having cruise control..only a little thing but makes a huge difference, especially for a new rider like Mrs P
[url]
[url]
Posted: Thu Apr 20, 2017 7:49 pm
by bigtwinthing
taxed and insured it. 1 day to go.
Posted: Fri Apr 21, 2017 9:51 am
by fabiostar
removed this from the rear wheel
was clean shitting myself incase i damaged the rear dymag
sods law the only bearing or seal on the whole bike i didnt replace let go..again every days a school day.
Posted: Fri Apr 21, 2017 4:52 pm
by podman
fabiostar wrote:removed this from the rear wheel
V lucky indeed, as you say, the thing you overlook or make an assumption on will come back and haunt you later..
Posted: Fri Apr 21, 2017 8:15 pm
by uk13iker
Cleaned the MT and polished headers one side of headers on vtr will post some pics of the polished side and side I haven't done when I get home from work in the morning. If anyone's are brown stained or rusted search harpic on down pipes on YouTube and look how good it is. It's the harpic plus 10 or X 10 toilet cleaner does a great job and then polish makes it so easy.
Posted: Sat Apr 22, 2017 2:06 am
by mik_str
Finished getting my bike ready for the riding season today.
Mods/updates for 2017:
- replaced screws holding carb butterflies in place with lower profile units (which were ground down as much as possible); improve airflow
- built a new airbox lid (ie. "Filter-in-lid design) with a larger filter element (area is up 40% over previous version); also improved volume and clearance over funnels slightly, as well as raising the tank a bit to improve airflow into filter/airbox/engine
- matched carb throats/intake collars/intake ports; did some minor dremmeling to latter two to provide a smooth and uniform channel for the air, again to improve airflow
- put thermal barrier on underside of airbox and carburetors (cooler airbox and carbs mean cooler air, better air density for improved power); minor, I know, but it was cheap...
- To improve response, I drilled a small additional lift hole in each slide (was running single hole before, just added 15% more area)
- cleaned front caliper pistons
- tightened steering bearings and replaced handlebars (with black version of same) and stem nut (blue Ti); red was just "too much" (has a stealthier look now)
I am not expecting anything close to major gains from the intake side changes, but they should improve response (which was already great) slightly if nothing else.
Will empty out the old gas, pour in some fresh stuff, re-install battery and I should be good to go.
To come shortly (get dealer to do it):
- new tires
- new chain and sprockets (gonna try 15/40 gearing)
- change fork oil
Posted: Sat Apr 22, 2017 10:59 am
by sirch345
It's the fine tuning that counts Micky, as you've proved before
I'm being lazy I know (but my excuse is I really should be up in my workshop and not on here
) but what does 15/40 gearing relate too, would it be lowering the gearing by something like half a tooth less on the rear sprocket if there were such a thing
Posted: Sat Apr 22, 2017 2:22 pm
by mik_str
sirch345 wrote:It's the fine tuning that counts Micky, as you've proved before
Yes, trying to optimize everything and leave nothing on the table; more power and better running through optimisation. All the big pieces are in place, the game now is to get the most out of all of them.
to answer your gearing question, 15/40 is almost the same as 16/43, just a slight bit taller (16/43 yields 27.3 km/h per 1000 rpm in 6th while 15/40 gets you 27.5). Am running 16/42 at the moment and wanted something just a bit lower....
Posted: Sat Apr 22, 2017 6:25 pm
by StormyRob
I'll put a more detailed post on later but today I had a f#@@ing nightmare getting to Grainstorm.
Had a lot of help from fellas on the way who held back with me and even went to get fuel and batteries! Long story.
Anyway at Grainstorm the running issue was solved. Bad spark plug. Was new but I think someone may have dropped it
Serious thanks to the lads for sorting that. Couldn't have sorted it that way without it.
She runs so bloody well. The reg rec was also shafted and that has now been sorted.
Unfortunately on the way I dropped the bike!!! Not too bad, some scuffs but very frustrating!
Posted: Sat Apr 22, 2017 9:39 pm
by macdee
The stuff of nightmares
