sat like a Richard wire brushing rads that wont even been seen with the bodywork on
Read my thread 'And so it begins' and you will see my frustration !!!!!
- agentpineapple
but you will knowfabiostar wrote:sat like a Richard wire brushing rads that wont even been seen with the bodywork on
i'm just as sad, I had some spray paint left over from my fork lowers, so I sprayed the rad grills with it.....
i'm a right tart.....
Last edited by agentpineapple on Tue Feb 07, 2017 5:20 pm, edited 1 time in total.
agentpineapple wrote: i' a right tart.....
a fair self assessment by both of you
- agentpineapple
I offer no rebuttalAMCQ46 wrote:fabiostar wrote:sat like a Richardagentpineapple wrote: i' a right tart.....
- bigtwinthing
agentpineapple wrote:I offer no rebuttalAMCQ46 wrote:fabiostar wrote:sat like a Richardagentpineapple wrote: i' a right tart.....
its always "butt" with you AP
guilty as charged lolAMCQ46 wrote:fabiostar wrote:sat like a Richardagentpineapple wrote: i' a right tart.....
Stripped a set of forks yesterday, what a faf.
Nothing complicated, just bottom of the range 43mm conventionals.
Could I separate the station from the lowers, er no.
After giving up on the slide hammer method, I bolted an old cr250 lower yoke to the station & twatted it till my arms were aching. Still no go.
Good job the stations were knackered / bent beforehand because they were dented all over after a lump hammer wielding fit of rage.
I had to use a bottle jack in the end, base on the outer top & jack pad on the CR yoke.
After a LOT of pumping it finally managed to pull/drag the station bearing through the slider bearing. I thought at one stage it was going to fire the station harpoon style through the roof.
I've done many forks over the years & have never seen this before. Only thing I can think of is that the previous owner fitted the wrong bearings before.
After the separation, I had to collapse & cut the slider bearings with a cold chisel to get them out.
3 hours. Propper faf.
KermitLeFrog wrote:Put it somewhere comfy....podman wrote:Good work..I wish I had a decent man cave, with some room, heat and a bike ramp would be nice too , on cold days like this I cant get anything done in my single garage rammed with bike, cycles, fridge/fzr and all that other domestic junk..MacV2 wrote:Got out to the MacCave & did something productive...
Stripped, cleaned & rebuilt a set of callipers front & rear...
Nice one,
I actually got in home today after buying it last November, goodbye GSXR, hello storm.
My friend owns & runs his own specialist motorcycle transport company and short term storage, which proved handy on both fronts.
Never had a yellow bike before, its growing on me..took it for a quick spin, feels really nice to ride and so much more comfy..
[url]
Someone mentioned a few days back storm prices had risen but to put it into perspective, someone has paid more for this imported , battered Honda NS400 missing a fairing and many major components than a 2 owner, 6,000ish mile 2002 'storm...
[url]
[url]
[url]
[url]
[url]
Been busy with the flat track project, removed the top frame spars & majority of the rear subframe.
Engine placed in the frame, yokes fitted with shortened Vara forks. (36" same as the Cbr600fy) with Renthals.
Vtr swingarm & linkage fitted with 10" eye to eye wooden shock
We have a rolling chassis
Varastorm wrote:Been busy with the flat track project, removed the top frame spars & majority of the rear subframe.
we need photos
just bought a seat cowl so need to prime and paint in a red(ish) colour to match the bike
- agentpineapple
spent half a hour cleaning my friends headers, used 3 different grades of sanding pad and wd40, all done by hand whilst the headers are on the bike, dammed if i'm going to risk removing them. i'll do a little more tomorrow evening after work. ignore the wonky lower fairing, mangled allen head bolt means I can't remove it just yet, so I bent it out of the way
