Found it. I was using the wrong common on the relays. Putting it all back together now.tony.mon wrote:Sounds like you have the "latch" side of the relay connected to a permanent live instead of a switched live.KermitLeFrog wrote:Ever since fitting headlight relays my battery has been discharging more than it should. My optimizer is getting hot just trying to keep up with it. So, as a side note, the battery is knackered. Has been dodgy for a while. Imagine my pleasure when the local motor factors have a new one (by Joe Lucas, Prince of Darkness) for just 30 notes. Only 10AH (180CCA) but should be lot better than the old one.
But, that's a digression. Even with the supply side to the relays disconnected I'm getting a 114 mA leakage and you can hear the relays chatter when I connect the battery. The only supply to the relays is the solenoids now going through the switch block. WTF? Anyway, fairing off and diagnosis to do. May not be arsed tonight though.
You need to find a circuit which is only live when the ignition circuit is active.
Most people seem to use the rear light or brake light live feed but I use one from the rear of the clocks as the cable run is shorter, therefore lighter.
If you are able to measure load when the battery is connected; before the ignition is switched on, you have the wrong latch sensor connection.
Had a busy bike weekend. The Storm has been sitting awaiting electrical treatment so I've been thrashing around on the KTM. Then this afternoon did some bike swapsies. Red Storm to garage after a clean and some TLC on a rusty chain, R6 back to mine.
I keep on thinking of selling the R6 and then, like today, I take it for a ride. You need to be in the right mood and have the right roads but...... When that all comes together the thing is unbeatable. The Storm is fun every day, the R6 needs a special occasion. Full throttle above 10k and my nipples stick out like hat pegs. And the NOISE (from the open pipe). It's a standard 2000 model (except for the pipe) but it carves lines like a very sharp carvy line thing. Nightmare in town and so easy to make a rock of getting off the line but, on the fast swoopy stuff it makes you feel like a God. I'm not sure if I'm faster on the Yam. It just feels like it. Guess I'll keep it for a little bit longer....
