no start, solonoid just clicks
Re: no start, solonoid just clicks
popkat wrote: Thu Feb 03, 2022 12:21 pm have you tried bridging the solenoid connectors with an insulated screwdriver ? this will by pass the solenoid, if the motor turns then you have a duff solenoid.
Also if that doesn't work remove the starter motor and bench test it.
Paul, A stupid question probably, but I'll ask it anyway :eh:
You have got the battery connected the correct way around as in RED Positive (+) cable to the Positive (+) battery terminal :?:
sirch345 wrote: Thu Feb 03, 2022 4:15 pm
That would / should blow the main fuse or you'd get smoke form the wires... don't ask how I know... :shh:
