LED rear light
TaxiDriver
Re: LED rear light
Post by TaxiDriver »
tony.mon wrote: Mon May 31, 2021 8:34 am Nice job.
Just check it every so often, I've had two of these self destruct from vibration, where the circuit boards had only been glued into place. I think it's movement from the light's flexible mountings rather than engine vibes, I reduced the amount of light movement by adding a penny washer or two to the rubber mount, which seemed to solve the problem.
Rubber mounting was there to try to protect the lamp filaments, but LEDs are more robust, so less flexibility is ok.
Will keep an eye on that, thanks.
The brake light is very bright,not shown on the pic,you'd have to be blind not to notice it.....
aah I see a patern emerging...... :cool2
Re: LED rear light
TaxiDriver wrote: Mon May 31, 2021 6:11 am All done and dusted......
Much brighter and with the brake light manager should help to back off
tail chaser's......
Oh yea,the red wire from the light is power not earth as suggested in a reveiw
on ebay.....
At least you are sorted now :thumbup:
