Another Got a box in the mail......
Re: Another Got a box in the mail......
8) 8) 8) Amazing to see all those lovely parts Mike :thumbup:
Are you degreeing all four camshafts or just two :?:
sirch345 wrote: Sat Mar 23, 2019 10:15 pm 8) 8) 8) Amazing to see all those lovely parts Mike :thumbup:
Good eye there Chris.....I will be doing all four but was only able to lay hands on 2 used gears.
So I have to make some calls to locate a second set :thumbup:
You can file out the slots in standard ones, they're hard but a good file will still work.
Bridgeport and a rotary table is my preferred way but a file or dremel will do :thumbup:
Plus it is easier to do by hand, if needed, now that I have a set of patterns. :D
8541Hawk wrote: Sat Mar 23, 2019 10:47 pm
Ah I see :thumbup:
Is the compression ratio for the Mori pistons different than JE pistons :?:
sirch345 wrote: Mon Mar 25, 2019 10:09 pm Ah I see :thumbup:
Yes it is different. The Mori piston are 10.4:1 (or the same as a SP1\2 for reference) , so a bit lower than the JE pistons but on the plus side that gives you a bit more leeway to work on the heads without getting the compression too high.
8541Hawk wrote: Tue Mar 26, 2019 2:02 am
Good information to have thanks Mike :thumbup:
