high RPM misfire
shoot
Re: high RPM misfire
Post by shoot »
G'Day,
Did you fix your problem????? I am having issues with mine idling poorly and stalling, but have also had it miss at high RPM's (above 8000 with WOT). I have pulled the carbs off and am cleaning everything but haven't got it back together yet. The only thing that I have found is a potential air leak with the vacuum pipe that goes from the air circuit on the front carb to the PAIR soleniod. I am binning the whole PAIR system and will let you know how I get on when I get it back together, but would be interested on knowing if you have found the culprit on you bike??
Regards Mark
StuartWags
Post by StuartWags »
valve timing 180 degrees out?
shoot
Post by shoot »
Hi,
Mine is now running great. Idling properly and no 8000RPM misfire. Cleaned carbs, removed PAIR system and fitted new plugs and vacuum lines. I cant say which was the culprit as all the work was done at the same time. Hope this helps.
Regards Mark
