Frame Brace
StormyRob
Re: Frame Brace
Post by StormyRob »
Solarboy
Re: Frame Brace
Post by Solarboy »
Thanks Rob,
If we don't learn from our mistakes we are destin to repeat them
Re: Frame Brace
i think hawk summed it up with frame bracing. for the road good yokes.forks and rear shock are the best call, or at least the first call..
i have standard frame with good front end and by the time you get it outa shape, you are doing really silly things..
on the flip side i have one with enough bracing to build a bridge out of as its a spondon ex race bike and i have yet to get it outa shape and iv tried me little best believe me :lol: .
so yes it works but only when applied to the correct parts of the frame..but still depends on having good sussies.
as for the rogered forks i have a set sitting here i took of one of mine and i have to say he does a dam fine job of getting the very best out of what really started life as budget forks from honda..
Re: Frame Brace
You might want to rephrase that :P
StormyRob
Re: Frame Brace
Post by StormyRob »
StormyRob wrote:Sorry but it was snowing today so wasn't in the shed. Will try again tomorrow. In the meantime I had these ones saved.
Sent from my SM-G935F using Tapatalk
OopsImageImageImage
Re: Frame Brace
so thats the missing bits from the forth river bridge then :lol: :lol:
Martinz
Re: Frame Brace
Post by Martinz »
fabiostar wrote: Tue Jan 16, 2018 9:15 pm i think hawk summed it up with frame bracing. for the road good yokes.forks and rear shock are the best call, or at least the first call..
I understand, SO guess the next question is , whats the "correct part" of the frame ? Need to get a little email together for Roger.
Susspension is fully sorted front and rear.
Martinz
Re: Frame Brace
Post by Martinz »
Bloody hell Rob. Thats Full on !! Thank you very much for the photos, exactly what i needed.
Al
Re: Frame Brace
Martinz wrote: Thu Jan 18, 2018 10:29 am Bloody hell Rob. Thats Full on !! Thank you very much for the photos, exactly what i needed.
Al
pretty much the bracing that Rob has on his frame.. the spondon version i dont think you will get because it has the ears on it as they are called. tho a man on here has a spondon chassis for sale.
heres the spondon version.
Re: Frame Brace
fabiostar wrote: Fri Jan 19, 2018 8:19 pm pretty much the bracing that Rob has on his frame.. the spondon version i dont think you will get because it has the ears on it as they are called. tho a man on here has a spondon chassis for sale.
That is a good example of the difference between a "race" frame and a more "street" based frame. One question I do have is are the flat bits added to the top front of the lower frame rails there in place of the stock plastic heat shield?
Can't see any reason other than blocking side drafts for that bit from this angle.
Re: Frame Brace
Robs frame has most of its extra bracing at the front, the spondon seems to have most of its bracing at the rear of the chassis. and not all the spondons have the same bracing, iv seen several different versions or at least seen pictures of them..
Martinz
Re: Frame Brace
Post by Martinz »
Al
Interesting. Would you be able to pm the deets of said member with the frame for sale please mate ?
