Front end alignment issue after crash repair
jchesshyre
Re: Front end alignment issue after crash repair
Post by jchesshyre »
No you're right it does a little bit in the flesh as well, but I think this is caused by the same issue.
Odd that the handling feels great despite this!
jchesshyre wrote:Here ya go. Again, fairly hard to see but it is just visible.
Anything else I should check before I order a new steering stem? Was pleasantly surprised to see they go for only about £30 on ebay.
yup thats how mine was aswell but mine just tapped straight after loosening everything. 3 or 4 good taps and its straight and every thing lines up..
jchesshyre
fabiostar wrote: yup thats how mine was aswell but mine just tapped straight after loosening everything. 3 or 4 good taps and its straight and every thing lines up..
Very odd. Admittedly I used a wooden mallet, but I gave it probably fifteen hefty taps in total and it's no different.
Was it definitely only the top yoke bolts you loosened (plus the stem nut)?
Steve6088
Post by Steve6088 »
Ive got a set of yokes you can have cheap.
yeah just top yoke and main stem nut... im thinking it looks like mine was but maybe something else is bent on yours..just strange that it looks the same as mine
jchesshyre
Before I get spannering and swap the steering stem, could this issue also be caused by a bent swingarm or even a bent frame? I would really have hoped they'd have checked that, and also I'd have thought it would cause chain alignment issues and I've checked that with a laser tool and it's fine.
its a front end problem....
fulviogsx
Post by fulviogsx »
It can also be the lower clamp bent....
The best and fast way to check the clamps (if the forks are ok) is
1) lift the bike from the engine (front wheel free)
2)loose the stem nut
3)loose the upper clamp (both left and right)
4)loose the lower clamp.both the fork have to drop down freely.if they don t,clamps are bented (usually the lower)
It'll be the lower yoke and clamps that are bent.
Take it off, turn it upside down and lay a steel rule across each clamp and you'll easily see any problem
