Page 2 of 5
Re: Newbee
Posted: Fri Jul 21, 2017 9:02 am
by Geeman
Hi...change the r/r...what does that mean...???
Re: Newbee
Posted: Fri Jul 21, 2017 9:51 am
by MacV2
Geeman wrote:Hi...change the r/r...what does that mean...???
Regulator /Rectifier...or as its know around here the Rectumfrier...
The black oblong block 3 yellow wires 1 red 1 green... Take the electical juice from the generator, regulates & rectifeies it before sending it to the battery... If it fails, & those ones do due to heat cycles over time...It can overcharge the battery, boil the battery dry, melt the wiring, screw ya clocks up, burn ya elbow...
You need to fit either a latter fined type from either a late model Storm or a host of other Hondas or splash some cash & fit a Mossfet type...
A later model finned type yesterday...
viewtopic.php?f=38&t=41255
When asked about it's older relatives it replied...'They are shite dude, buy me & stop worring about a failure...Oh & as long as your block conector is not a melted wreak I'm plug & play''...
Cue Wicky & his Sh*t R/R pic...
Re: Newbee
Posted: Fri Jul 21, 2017 9:54 am
by alanfjones1411
What he said.
Re: Newbee
Posted: Fri Jul 21, 2017 9:59 am
by MacV2
Geeman I have sent you a PM.
You should be able to read it but not reply...get posting & get 50 posts for full access.
Re: Newbee
Posted: Fri Jul 21, 2017 10:49 am
by j4weeson
Hello and welcome!
I got my manual ones from Ade and would recommend them.
Re: Newbee
Posted: Tue Jul 25, 2017 10:20 pm
by Geeman
Hi again
Ordered cam chain tensioners from Ade. Fitted Renthal rear sprocket. Clutch and brakes bled and now working fine. New in tank filter fitted. Getting it road ready and MOT'd then during the winter i will repaint calipers...forks and get swingarm polished or powdercoated. Getting it booked in at Biketec in Stoke for setting up and tuning and fitting the cam chain tensioners...dont trust myself...
Re: Newbee
Posted: Wed Jul 26, 2017 10:32 pm
by Geeman
Well its all back together and running well. Doesnt look much different to the first photo i put on here. But its cleaner...all the dodgey wiring has gone and now sorted...the dodgey indicators sorted...the only problem is i think the clutch reservoir is leaking slightly. Oh and the headlight is rubbish.
Re: Newbee
Posted: Wed Jul 26, 2017 10:53 pm
by sirch345
Welcome aboard Geeman
Nice work with the polishing,
Re: Newbee
Posted: Sun Aug 13, 2017 9:38 pm
by Geeman
Hi all
Bike is going to Biketec in Stoke on Wednesday for MOT..Manual cam chain tensioners and tuning...fingers crossed it will be all good as have been asked to go out for a run on Wednesday afternoon/evening..weather permitting...keep you posted.
Re: Newbee
Posted: Sun Aug 13, 2017 9:50 pm
by StormyRob
Geeman wrote: ↑Sun Aug 13, 2017 9:38 pm
Hi all
That must be costing a fortune. You would save quite a bit by doing the ccts
Re: Newbee
Posted: Sun Aug 13, 2017 10:14 pm
by Geeman
hi there...
I know where you are coming from but at the end of the day if I mess it up the engine is toast. The guy is very good and I don't feel confident fitting them and he has done them before. The bike cost me £1250 with a load of bits including a Abba stand which I have sold for £50 all the other bits will be up for sale. It hasn't cost much so far...proberbly in it for £1400 at the moment. I have a set of wheels with very good tyres which I might swap for the scrubbed tyres that are on at the moment...extra rear light...top yoke and straight bars...I am doing it to keep so I want it running right...thanks.
Re: Newbee
Posted: Mon Aug 14, 2017 10:04 pm
by Geeman
Re: Newbee
Posted: Tue Aug 15, 2017 1:36 am
by VTRDark
Nice use of circular saw blades on the wheels
You have a bit of a Blue Flame theme going on with your bikes. I'm guessing the cans where part of the deciding factor when purchasing. What's HECKS? You may regret getting rid of the Abba stand.
Re: Newbee
Posted: Tue Aug 15, 2017 7:34 am
by Geeman
Hi
No idea what HECS is...it was on the fairing already.
Re: Newbee
Posted: Tue Aug 15, 2017 9:16 am
by StormyRob
VTRDark wrote: ↑Tue Aug 15, 2017 1:36 am
+1 on that. The abba standis by far the best piece of kit I have
