Not a Moriwaki. So what's it worth?
stealthbomber
Re: Not a Moriwaki. So what's it worth?
Post by stealthbomber »
That is gorgeous, you sir have real talent there :thumbup:
In the land of ham fisted, I am king
Very smart indeed 8) 8)
All credit to you, you've done a lovely job :clap:
I do like the exhausts ,
motocorsaro3
Post by motocorsaro3 »
Thanks eveyone for your positive comments. It makes all that time in my garage seem worthwhile! Unfortunately, my Wife is not of the same opinion...
Then divorce her and get one that is more complying:-) (they are out there)
-Floris-
Post by -Floris- »
Those exhausts :erection: :Stewy: , actually the whole bike is really beautiful!
It's sad that, in our blindness we gather thorns for flowers
motocorsaro3
Anodised titanium was out for the exhausts, as was genuine Moriwaki. PipeWerx were brilliant in producing exactly what I wanted. Top quality job. It was then a case of out with the TIG welder and modifying some link pipes to get them to sit right. I'm not entirely happy with the postion, but it's OK. I'm limited by the RSVR subframe & hangers.
Did you just make them longer ?
motocorsaro3
I extended them by about 40mm and welded on the laser cut spring hook retainers that Pipewerks use. You really need to back purge the pipes with argon when you weld them up.
Thanks for that , fancy doing another set ?
motocorsaro3
I think what I'd rather do is send them to Pipewerx in the winter and ask them to modify the 90 degree bend in the left pipe to turn tighter under the swinging arm. Once they'd got the bend sorted to my satisfaction, they could then reproduce them for you.
FactoryPro 1.1 Carb Kit with Titanium needles
Cleared out airbox with HPower CNC Velocity Stacks & foam panel air filter
CBR1000RR stick coils & Iridium spark plugs
FactoryPro Shift Star & Detent Arm/Spring
FactoryPro Ignition Advancer
Has it been set up on a dyno and have you the the results?
motocorsaro3
Literally, the engine has idled for 30 seconds since I built it. So I have yet to dial in the fuelling with the butt dyno. I can usually get it as near as dammit that way. Others I've done have been so close to optimum that it has not been worth any further adjustment after a dyno run. I would expect 100-110ish at the back wheel. If I went for JE pistons and flowed heads, that would be worth another 10. The biggest gain is the weight loss. Just wheeling it around, it feels featherweight compared to how it was. That with the lower gearing & quick action throttle will make it fun. I have one of the new generation Techtronics quickshifter coming too.
Z28DUNC
Post by Z28DUNC »
Sooooooooooo , are you going to split it down or try and sell it complete?
If you were to split I recon you could sell most of it in a week. Most of us would have bits, we're like rabid dogs for second hands parts.
:lol: :lol: :lol: I know that one :biggrin
:eek2 :eek2 :eek2
I never did get it perfect and finding someone to work with TI is next to impossible unless your rich.
Very nice bike you have there. I would be interested in a set of them cans too. My Arata's are dead :( :( :(
