Studs
Re: Studs
Wheres that link with the cutting a bit of the head away with a dremell...?
Re: Studs
TonyW650 wrote:Right I have a question, What type of gas torch do you recommend, I've been at it for over a hour with a butane torch and its still a no go, so Im assuming its not getting it hot enough or the heat is being dissipated to quickly!
You're probably sorted but I use a Rothenburger blowtorch with Mapp gas. Gives a good hot burn. :thumbup:
Re: Studs
make sure you apply the heat to the top of the bolt, along the top of the engine, you don't want to heat either end, or get anywhere near the frame, well that's what me and carl did, looking bad I think he just wanted to set fire to my bike...... :(
TonyW650
Re: Studs
Post by TonyW650 »
We did set fire to it, mix of GT85 and WD40 and easing oil burns well.
Got it proper hot 10 to 15 mins on the alloy castings on the block, where the bolt goes and no go, frame was getting hot from heat transfer.
We have had plus gas on it this evening, and even broken the handle on a wooden club hammer and its not moved.
So its going to be hacksaw time by the looks of it, and then drill it out.
butt!
