Pictures - is there another way
Please use this forum to ask our resident IT geeks advice.
Re: Pictures - is there another way
:lol: :lol: :lol: :clap: :clap: :clap:
Well done, got there in the end ay. Have you seen the how to post pictures in the read me in my signature.
magnum
Post by magnum »
Try using taper talk on your mobile works for me.
Sent from my C6603 using Tapatalk
"It may be yellow but it ain't no chicken"
Beleif
Post by Beleif »
I read it Carl, Cheers.
Of course I am getting old and impatient, so I probably skimmed through it.
Is that you on the beach with the Bag Pipes...& not much else ...? :lol:
Is the shagged out GT550 wit the side car your pride & joy...?
Hvornum
Post by Hvornum »
Semi-old thread, but i'll pitch in with a tip.
If you're using Google+ for any reason (i do with auto backup for laziness etc), here's a neat little trick:
First you enter the photo section and select an image:
Then you right-click on the image, and copy the url:
Finally, you paste it in as a normal
Code: Select all
[img]<link>[/img]
with the slight exception where you can change the width by modifying the url directly, the highlighted part says w779, chagngin that to w3840 would make the width 3840 pixels (which happens to be the pictures original size).. or you can change it down to w300:
In my case i usually use 800 as it fits most older devices and phones nicely. :)
You can also use a special link for google drive to at least hot-link images:
https://drive.google.com/uc?export=view&id=<fileId>
Where the <fileid> is replaced with whatever ID is given when you select a item in google-drive and selects "share" :)
Note: Both these scenarios require the picture to have the private settings on the individual image set to "Anyone with the link" or "public" to work :)
Anyway, since Google+ functions as my main backup location for images it might as well serve as a permanent web-link service (much like Flickr, Imgur, etc) :)
