Styler4077 wrote:Benny
I'm looking at a Hydrovane single phase unit.
Expensive but looks like the one to go for to me.
Low noise as well as no need for a tank
Any thoughts on these? As your the man in the know.
Styler
yeh ring up compair in redditch direct theyre a lot cheaper. vanes pwn piston compressors.
im guessing it'll be a 501-502 or 504
they will happily stay on load all day and though you dont need a receiver, they work better with one, as for example a 501 is only like 5cfm output so will struggle to run a sandblaster or spraygun direct.
also, if you're spraying, dont put the compressor in the same room as it will suck overspray in and wreck the filters & cooler
they last forever if you keep on top of maintenance.
ive worked with vanes for 20+ years. just stay away fro the old 23 / 33 / 43 range cos theyre fiddler lol.
mattei do a cheaper range of vanes - its a lot of engineering for your money when you see all the intricate parts, but theyre very simple to maintain.
if you let me know how much you want to spend i can find you a good deal but you can sort your own carriage
