![Smile :)](./images/smilies/icon_smile.gif)
do you have a pic of the front showing the removed sidelight replaced with mesh?
Very nice
sirch345 wrote:It'll be interesting to see what the dyno has to say when you get around to it, but from what you're saying it sounds like you made some more gains again![]()
I would say that's because they manufacture for various bikes. So not quite so bike specific. Big companies like that are not too bothered if their sales are goodNot sure how Yosh ever came up with such lame specs for their cam installation but, suffice to say, it`s possible to get much better results by changing the timing slightly.
Ah, slightly advanced, but with an additional four degrees of overlap.mik_str wrote:Hi Tony,
FYI, cams are Yoshi Stage 1s (more lift and duration than stock, more lift but less duration than Moris). I origianlly had them set at 107/110 lobe centers (intake/exhaust; just slightly off the Yosh recommended settings of 108/110). However, after the rebuild a little over a year ago, I was trying to figure out why the dyno numbers weren`t better (after all, not much was spared if you look at my list of mods). In going over the matter with Roger D (can`t say enough great things about the man), he noted that the cam timing specs were extremely conservative. I had a look (fairly new to this, I am) and decided to have them re-set to 104/108 (had DLC-coated tappets put in at the same time). Bingo! Found the missing ingredient. It pulls much harder now and it seems as though all the mods have finally all come together (exhaust, billet stacks, BMC filter,....). Not sure how Yosh ever came up with such lame specs for their cam installation but, suffice to say, it`s possible to get much better results by changing the timing slightly.
