Phimosis wrote: go into the 29mpg bracket looooooooooooooooool![]()
I long for those days, but I keep opening the throttle...
I will ride immediately to Kent. That price is just too good to pass up. £80 on fuel - £3 saving = approximately £77 extra!!! Bargain.tony.mon wrote:How much????benh89 wrote:
Should I expect fueling problems with aftermarket cans? I haven't ridden it yet so I don't know how it feels. Given the bike's history, I suspect the carbs are still factory configured, but I can't be certain as I haven't checked yet. Once I'm on the road I'll be getting the power and air/fuel mixture tested (£45 at Hodges Motorcycle Works, Penzance).![]()
Ride immediately to Kent, where you can get a power run with stoichiometric ratio readout for only £42. (mention my name).
Undoubtedly the dyno operator will tell you that you need to set the bike up properly to suit the cans.
Make sure that you at least clean the air filter before you take it in, and if you were planning to fit a K+N or BMC filter, or dynojet kit, do it beforehand.
Yes I did. Why do you ask?vtwin wrote:Did you say you bought this bike from a dealer?
The dealer is a lying MF period. They are all born of devil and big bitch, they will tell you are a sex god with a mammoth phallus and you did that thing with it only a few have done before, your stylish, can drink with the rugby team and defeat all but the tight head prop, you wear great clothes and gok wang wants to take you out......then you sign on the dotted line........check it out, all of it.benh89 wrote:I will ride immediately to Kent. That price is just too good to pass up. £80 on fuel - £3 saving = approximately £77 extra!!! Bargain.tony.mon wrote:How much????benh89 wrote:
I'll just be riding it for a while to get to know the bike. If it feels fine, it'll probably stay as it is unless I feel really adventurous.
Comments are appreciated, cheers.
When I was behind ya, I was always on the brakes.................tony.mon wrote:Phimosis wrote: go into the 29mpg bracket looooooooooooooooool![]()
Jazzscot wrote:http://www.pitchero.com/clubs/perthshir ... r_id=13081Phimosis wrote:
I can drink like fook![]()
They offered to, but I chose to do it myself. I trust no one, but me in all things and like to do all the work myself, no matter how easy or difficult. It would have been dead by the time it arrived anyway no thanks to that stupid alarm. I have applied to do Automotive Engineering at university so I think I should be undertaking basic jobs. On that subject, has anyone here done an Automotive or Mechanical Engineering degree? I'm 22 now and slightly skeptical about returning to university. Not sure if it's the right move.vtwin wrote:Why didn't the dealer fit the new battery and check it over before he sent it out?
Yeah if you are removing the crapoiler replace the tee piece with a straight through or blank the t bit off.benh89 wrote:I'm not a big drinker... I'm only 5'9''.
Wow, my first thread and it's on fire!
Will the removal process be simple? i.e. trace each wire from the control unit to where it inserts into the loom, detach and re-connect original wires, soldering if necessary? Then wrap it up in shrink wrap or electrical tape? I understand that sometimes, much of the original loom is removed and so re-connecting original wires can be difficult.
How about removing a Scott oiler? Do they make a lot of mess? I traced a hose coming from the unit and it attaches to a t-shaped connecter underneath the tank. Is this connected to a vacuum hose?
I hope I don't find anything else to remove or alter or I'm never going to ride the bloody thing!
