Page 2 of 20
Re: Ducati 750ss First time project
Posted: Fri Oct 28, 2011 11:01 pm
by tony.mon
Just one comment, that I would have asked them not to coat the areas where the beads of the tyres sit, as there's less grip on pc, and the tyres might move on the rims.
You could scuff it up a bit before fitting tyres, though.
Posted: Sat Oct 29, 2011 1:39 pm
by Flatline
Thanks for comments guys
Tony I will bear that in mind, cheers
Posted: Mon Oct 31, 2011 1:48 pm
by Flatline
First but no doubt not the last problem
Removing the bearings from the cush drive and it breaks
So a new cush drive required
Oh well
Posted: Mon Oct 31, 2011 7:08 pm
by agentpineapple
i wouldn't do another bike, it's a pain in the butt. i wish you all the luck in the world with it, it will test your patients more than anything else.....
Posted: Mon Oct 31, 2011 8:48 pm
by Flatline
Yep, but I look forward to people seeing it and hopefully going "wow!"
We live in hope
Posted: Mon Oct 31, 2011 9:00 pm
by agentpineapple
the best bit is no one will have the same bike as you.........
Posted: Fri Nov 25, 2011 4:42 pm
by Flatline
Bit of an update
Found this, which is almost exactly what I intend doing to mine although I will be using different colours
I am using a monster loom to cut down on all the wiring
Hope you guys like the way its going
Update: DuCafe Racer
Posted: Sun Jan 01, 2012 6:42 pm
by Flatline
Just spent a couple of days put the bike together to get a look at what it will look like
Been cleaning up some of the parts ready for coating
It gives me a chance to look at where to remove lugs and brackets on the frame before I get it powdercoated again
Hoping to get an official workshop/parts manual so that I can see where things go
Comments gratefully received, though not always accepted
Started by getting the engine on the blocks and frame attached
Attached to the scaffold bar that is fitted across the room
The lower headstock bearing was a tight fit so turned it upside down and hit it with wood
Not sure if the upside down forks look strange.........hmmm
Maybe it's the gold that looks wrong
Will be looking for a single 8" headlight soon so a bracket is in order
Will have to make a start on the wiring loom as well
Link to the album:
http://imageshack.us/g/163/pa241532.jpg/
Posted: Sun Jan 01, 2012 6:49 pm
by benny hedges
it's coming along... but it still looks like you're sitting on half a loaf lol
Posted: Sun Jan 01, 2012 6:50 pm
by Flatline
Will be able to take it all to bits again soon
Posted: Sun Jan 01, 2012 6:58 pm
by Flatline
Posted: Sun Jan 01, 2012 7:01 pm
by Flatline
Just realised the front looks strange cos the wheel has no discs on
Posted: Sun Jan 01, 2012 9:19 pm
by agentpineapple
starting to look good buddy
Posted: Tue Jan 03, 2012 8:39 pm
by steeveeo
Hi Like yer 750ss
while yer got engine out check valve shims ,its much easier if its on the bench.
new belts.
get carbs cleaned ,set up
check fuel filter guaze in the tank before starting,tanks prone to rust.
I had mine kn filter and rejetted ,made a big improvement in power
bike got 2nd in run what brung at the bulldog in V twin class.(several yrs ago)
them where the days
original rectifiers prone to frying on them,upgrade available.
keep at it ,that thing will put a huge grin on yer face when ya whack it open
Posted: Wed Jan 04, 2012 8:02 am
by Flatline
Cheers for the headup Steeveeo
Some good info there
Regards
