Hello from Bristol
- hondasrock
Re: Hello from Bristol
hello mate, I converted to the twin thing last year and absolutely no regrets. spend what you can afford, but dont always go for the cheapest, you get wot you pay for to some extent, most 'bargains' are cheap for a reason!
HONDA Firestorm............your all TORQUE you are!
Ta to al once again for the welcome
On a side note AFAIK there is two "versions" of the VTR1000F with the later one having a larger tank and different clocks. Much else different other than that?
Ta,
Jack
Haha, aint that the truth! Money I've got should sort me out with a decent one.hondasrock wrote:most 'bargains' are cheap for a reason!
Ta,
Jack
No thats about all there is worth a mention.
- bikerpiker
Has the newer version not got slightly less power .....sure i read that somewhere
Stevie
- stormingjoe
- Contact:
power-colour you know it makes sense yellow being the most powerful of course
They got the tank larger by shrinking the airbox which managed to make it less powerful than the 16 litre tank model. I think the extra 3 litres doesn't add any extra mileage to it either.bikerpiker wrote:Has the newer version not got slightly less power .....sure i read that somewhere
Rich.
Ah I see! Even if the extra capacity did increase range it wouldn't really make much difference to me as I'll rarely need to do 100+ mile jaunts on her.cupasoop wrote: They got the tank larger by shrinking the airbox which managed to make it less powerful than the 16 litre tank model. I think the extra 3 litres doesn't add any extra mileage to it either.
Yep I think the earlier models make a teeny bit more power and the anniversary a teeny bit more than the earlier models but hardly worth a mention IMObikerpiker wrote:Has the newer version not got slightly less power .....sure i read that somewhere
The new ones also got a security codded ignition system which mine has and i get slightly cheaper insurance
Matt Black 04 model
Good call , it has the HISS system doesn't it? Totally forgot about thatcoledog wrote:The new ones also got a security codded ignition system which mine has and i get slightly cheaper insurance
- hondasrock
yep, and part digital clocks, oh and the bars are slightly higher, I think honda were trying to convince us that it was a touring bike, with that tank range, I think not !!!!!Beamish wrote:Good call , it has the HISS system doesn't it? Totally forgot about thatcoledog wrote:The new ones also got a security codded ignition system which mine has and i get slightly cheaper insurance
- Pete.L
Welcome Aboard fellow Bristolian
I've been off on me hols or I would have said 'Alright' sooner. There's a couple of us about town,Seven of Nine and Mark84 also have the privilege, you're only forth to admit your from Bristol I know of but I'll bet there's also a few shy ones out there lurking cause there are plenty of Storms buzzing about town
happy hunting, you wont be disappointed
