![Image](http://i871.photobucket.com/albums/ab275/buster6322/_57_zps5rk8qwci.jpg)
sirch345 wrote:
That's a job I've been meaning to get around to. I'm guessing you used a lathe to make yours Mike![]()
I know there for fine tuning .8541Hawk wrote:Its good for fine tuning in that it smooths things out and gives small adjustment but won't fix big errors.lloydie wrote:Especially for a bike that's that's got over 90k miles on it .agentpineapple wrote:looking good hawky, super clean.....
Hawk ...... How does the flow commander work ?
So its kind of the last bit to add IMHO
What size did you go for Lloydiesirch345 wrote:
I know there for fine tuning .lloydie wrote:
Sorry misunderstood your question.8541Hawk wrote:I know there for fine tuning .lloydie wrote:
But what do they do?.
Do they reduce the airflow into the main air feeds ?
Depends on the size you get .BrianC wrote:What size are those thread inserts and do you glue them in?
Great fix
Brian
I think mine are 8X1.25 but that is only because I had a box of Al cap screws that size.BrianC wrote:What size are those thread inserts and do you glue them in?
Great fix
Brian
When I got mine I road it 10ks from where i bought it to home. I bottomed the fork twice. First thing I did when I walked in the house was e-mail Robert Taylor in new Plymouth for new springs. Search Rogered forks on here to help with the valving.Cadbury64 wrote:T'was a big day today. I finished re-assembling the VTR, balanced the carbs, replaced a couple of missing or damaged parts from the PO, and then set off for my first proper ride. After rebuilding the forks, greasing the rear suspension, cleaning and bleeding the brakes, changing the oil and filters and fitting manual CCTs I was very happy to have everything working great.
I was glad that I'd read about vacuum lock after overfilling the tank as I experienced that first hand. Also (don' t tell anyone) I verified that my Jap market bike does indeed have a 180km/hr limited so I'll be addressing that shortly. I was pretty happy with the handling and found the turn-in much improved with the 6mm shock spacer, but I think I'll be re-springing and re-valving the forks sometime soon as they're pretty average braking hard into bends. The cleaned up brakes came good after a few decent stops and surprised me and the fork bump stops with their power.
Its a very different bike to ride to my VFR800! But very engaging and quite a bit steadier leaned over in bends. Probably more weight over the front wheel I suspect.
Yep I'll be getting me a set next time [THUMBS UP SIGN]Virt wrote:Converted Lloyd to our one true savior, Lord Metzeler![]()
