Trying to get better braking on my VTR and looking for some advice. I have fitted HBC pads, braided lines and long Pazzo levers. This has helped but still not great. My plan for the next stage is to fit SP1 calipers and if I'm still not happy get a Brembo master cylinder.
Has anyone out there done this?
A good plan for brakes?
- clayderman
- RedStormV
- Location: West Yorks (Bronte Country) - Home of the Negro Lesbian Cornet Players
- Contact:
Hi,
Welcome to the forum
A cursory search of the foum's thrown these up - well worth a read.
http://www.vtr1000.org/phpBB2/viewtopic ... r+cylinder
http://www.vtr1000.org/phpBB2/viewtopic ... =brake+mod
HTH
Graeme.
HTH
Graeme.
- Stormin Ben
My twopence
1. Give the calipers a damn good clean
I only ever use 2 fingers (max) on the brake lever and have enough bite to lift the rear
Remove the calipers and pads one side at a time
Carefully pump the brake lever -probably one piston will emerge
Clean it up, push it back in and repeat
Then block that piston and repeat -one more piston will come out
repeat until you've done all 4 pistons
THIS MAKES A MASSIVE DIFFERENCE
2. Fit quality pads
I highly recommend Bendix supersport or Carbone Lorraine A3's
NB NOT the SBK-3's
EBC's feel brilliant for the first few hundred miles but go off quickly and overheat with hard use
3. Blead the brakes thoroughly
Only once you've done all three THEN is the time to start making serious mods
NB the SP1/2 master cylinder will give more force but reduce feel
2. Fit quality pads
NB NOT the SBK-3's
But its not a very good one!
- clayderman
The higher the Dot rating the higher the boiling point of the fluid basically speaking, whether it's more refined or has different additives I don't knowgilson wrote:What's the difference between Dot 4 and Dot 5? It's for my track bike and I presume that Dot 5 is better? But why?
It's hard to look cool carrying toilet roll.
I have EBC discs and pads on mine, with braided hoses. The forks have been "done"
I find the brakes to be really good now - I can only agree re the checking of each piston and thorough brake bleeding. Just try the old cable tie round the lever overnight - you might be amazed at the difference!
Also, altering the span adjuster seems to make quite a difference to how the lever feels.
My front brakes are much better than the R1 setup on my TDM!
