Can any one recommend a good c spanner for the suspension?
The one that came with the shock fits but fouls on the sub frame and keeps slipping off as I think Mr Shultz must have had his wheatabix that day its bloody tight the only other way I can think of is to take the shock of and loosen it then refit
It’s a full type c spanner i.e. a semi circular one
c spanner
- Stormin Ben
i'll give it a go but ajusters ar right in line with the bloody subframe so the spanners at an angle and slips offStratman wrote:Have you moved the rear brake fluid reservoir out of the way? You can get that extra biot of angle that way. Also, when the c-spanner slips, you won't nick the pipe from the resevoir to the master cylinder. Experience is a great teacher
i'll have a look ben thanks see if it looks like it will fitStormin Ben wrote:M&P used to do a small one with a 1/2" drive hole on it
You could then get the ratchet on it
