Gents;
My 98 Storm has the nasty habit of not showing a netural light when in netural, this is a pain in traffic. Sometimes it comes on, some times it don't and worst, sometimes is flickers on and off. It happens when it is cold, hot, putting through traffic, or just after a rage through the twists.
Any thoughts on somehting that is loose, or could be adjusted or could be cleaned?
Cheers JS Stu.
Neutral Light
Neutral Light
"Not all who wander are lost."
-J. R. R. Tolkien
-J. R. R. Tolkien
- firestorm_al
- Site Admin
- Contact:
Stu,
If you haven't found the problem, it'll need a new switch if the wiring is ok. The switch is located on the left side of the engine, the connector is like a female bullet (covered in black plastic - this is the one you want), just above the gear selector shaft. Just ground the connector to the engine or frame and the light should come on, if it comes on and stays on, check it with the engine running (to add some normal vibration) then change the switch. First check that it's above the oil level or you will need to drain the oil first. Just use a deep socket and then use a little blue hylomar (however ya spell it) when you insert the newen, but don't over tighten it. It's a normal switch, nothin fancy and just operates from the gear selector drum in the gearbox.
Del.
Del.
No probs Stu,
Del.
VTR1000 (1)
Renegade Titanium Cans
DynoJet Kit
K&N
KTM620SC
SPA Dash
Works Titanium Exhaust
17" Talons soon
VTR1000 (2) Forsale Soon
Front
Racing Magnesium Dymag (Red/Gold) 17"x3.5"
AP 320mm GP Discs
PFM 6-pot Calipers (Black Anodised)
Revalved/Resprung '98 Blade Forks Modified for quick release mechanism
Spondon Endurance Quick Release Wheel Mechanism
Carbon/Kevlar 916 mudguard (held on with Triumph T595 clamps)
Braided hoses
AP Master cyclinder
Promach (my design) yokes (27.5mm) to take 50mm sleeved to 45mm (Grey Anodised)
Blitz headlamp, Carbon, with projector lamp and hand made Carbon mounts.
Carbon/foam dash, SPA com Tacho/Speedo/Shift Lights, SPA Digital Water/Oil Temp (White/Chrome), Hand made mounts
CR500 Renthals, Renthal Grips
All bolts are Titanium/Alloy
Rear
Spondon SB spec polished swingarm
Harris underslung rear caliper (Gold anodised)
PFM rear brake disc
Braided hose
Racing Magnesium Dymag (Red/Gold) 17"x6.25"
Renthal Gold Anodised Rear Sprocket
520 X ring HD Chain
Penske Race rear shock fully adjustable, length, preload, rebound & 2-stage comp (Gold/Black)
Chassis
Spondon SB spec polished modified VTR frame (Carbon inserts)
Spondon Grey (as per yokes) SB spec footrest hangers
Spondon Subframe modifed to take seat unit.
Carbon MVF4/916 seat unit with 916 Bipisto suede seat.
Hand made alloy undertray for battery/alarm/loom/coil/rear lights etc
Hand made alloy exhaust supports
Hand made Carbon exhaust hangers
Hand made complete loom incorperating Meta Cat 2 alarm/imobiliser, MCB's etc
Red Top 8 battery
Hand made alloy radiator & oil cooler mounting brackets
Hand made alloy coil mounting brackets
VTR Fuel Tank with modified fuel outlet (Red)
Private Number Plate (L7 VTR)
Extreme Steering Damper
Engine
Full Race ignition, fully mapable with software via a pc, uses standard ignitor box and modified to take standard Cdi if needed
Full Rainbow Titanium Moriwaki exhaust system
Revolution modified/vented Engine Cases
Close Ratio Gear Box
Japanese market softer clutch springs
Moriwaki forged high compression pistons
Stan Stevens Ported/Gasflowed Heads
Moriwaki Stage 1 cam shafts
Modified VTR Carbs (including pilot air jets) Factory Carb Kit
Fuel Pump
Samco water hoses
Large Setrab Oil Cooler with Braided Hoses and QD dry break oil connectors
Magnum oil filter plate
Modified Open Air Box and K&N Filter
Carbon Engine Covers on left and right cases
Modified Radiators with Carbon Covers
All bolts are Titanium/Alloy where possible
Power 122rwhp & 84ft/lbs torque. Dry Weight 170kgs
Del.
VTR1000 (1)
DynoJet Kit
K&N
KTM620SC
SPA Dash
17" Talons soon
Front
AP 320mm GP Discs
Braided hoses
AP Master cyclinder
Rear
PFM rear brake disc
Braided hose
520 X ring HD Chain
Chassis
Red Top 8 battery
Engine
Fuel Pump
Samco water hoses
- firestorm996
- Contact:
