Tanks
porkerhol;ic
Tanks
Post by porkerhol;ic »
Hi there....Does anybody know if you can fit a SP1 tank on a VTR? Just would look so much nicer...... James
cheekykev
Re: Tanks
Post by cheekykev »
No, it won't fit, totaly different tanks.
In fact they are totally different bikes.
Like what you do
Do what you like
haynesjones66
Re: Tanks
Post by haynesjones66 »
many tanks
Re: Tanks
haynesjones66 wrote: Thu Mar 28, 2024 7:40 am many tanks
Re: Tanks
tony.mon wrote: Thu Mar 28, 2024 11:15 am
The SP tank extends down into the rear subframe, so you'd have to repackage a lot of the storm electrics and battery at the very least.
You could cut and re-weld it, but then, you could do that with almost any tank.
Re: Tanks
:D :D
1971allchaos
Re: Tanks
Post by 1971allchaos »
I thought i would offer opinion on your question. The SP1 or SP2 fuel tank are much wider across the airbox upper frame. Not to mention the price for either series of fuel tank is alot more in price.
Now i read of member using Honda VFR fuel tanks of the same years... With some modification
