Did you adjust the steering
No but I'm thinking of fitting some pruning shears just in case...
- TaxiDriver
MOT on the Storm today,not ridden it for 10 months and boy did I feel those rear sets............
Out of interest which joint was it that was leaking MacMacV2 wrote: ↑Tue Jun 27, 2023 4:06 pm Finally got round to the post Devon tlc for Nue Red.
Sorted out the exhaust leak so hopefully less popping n banging. Whiped lots of clag off the swing arm... damm scotoiler. Topped up said scotoiler. Didn't adjust the chain after the 800+ miles...damm scotoiler...Hahaha. Took a leaf out of Tony's handbook of not cleaning it apart from the rear wheel had a wipe off
To be fair there is a hosepipe ban in place.
Rear header. It's a Moriwaki full system. Keep tightening the clamp but there was still movement with the weight pulling it down. I had a fiddle losening the can straps & popped the spring off the link pipe. This gave me the wiggle room to put a bolt through the footrest hanger. Should hold it all in place now. Just hope the bracket don't snap!sirch345 wrote: ↑Tue Jun 27, 2023 6:42 pmOut of interest which joint was it that was leaking MacMacV2 wrote: ↑Tue Jun 27, 2023 4:06 pm Finally got round to the post Devon tlc for Nue Red.
Gave Nue Red a run out. Picked up a smoked visor, filled it up ready for Sunday's run to Devon.
- freeridenick
Tried, and failed, again, to bleed my brakes. A bottle and a half of fluid and no joy. The master cylinder will be off to HEL by the weekend for testing. If it's not faulty I don't know what more I can do. .
Good to get the mot out of the way thoughTaxiDriver wrote: ↑Tue Jun 27, 2023 6:15 pm
Thanks for the reply Mac, for some reason or another it had slipped my mind you have the full Moriwaki system on Nue Red.MacV2 wrote: ↑Tue Jun 27, 2023 9:19 pmRear header. It's a Moriwaki full system. Keep tightening the clamp but there was still movement with the weight pulling it down. I had a fiddle losening the can straps & popped the spring off the link pipe. This gave me the wiggle room to put a bolt through the footrest hanger. Should hold it all in place now. Just hope the bracket don't snap!sirch345 wrote: ↑Tue Jun 27, 2023 6:42 pmOut of interest which joint was it that was leaking MacMacV2 wrote: ↑Tue Jun 27, 2023 4:06 pm Finally got round to the post Devon tlc for Nue Red.
Hopefully that should do the trick
Washed & polished Neu Red & The Murvinator.
I did take Neu red out for a spin yesterday... & did the nigh on 600 miles Devon run over the weekend so it does get ridden...
Nice tribute sticker Macster
Polished it, and had fun riding with a Ducati Panigale dude…
For all that extra money, on real roads, there’s not much difference…
Then again - I am a firestorm nut
. Sooo…
. Sooo…
Sold it, new owner to collect Saturday.
- Pete.L
Was it anyone on here Duffy?
Will we be seeing her again?
