Changing wiring loom difficulty
Dazza2910
Post by Dazza2910 »
Hi,
Is changing the wiring loom especially tricky or just time consuming?
Is it all just connectors to plug in? I'm happy enough getting access everywhere but never done it before so wanted to check and get people's thoughts.
Daz
Re: Changing wiring loom difficulty
Done it a few times...
Take a load of pics before you remove it so you can get the routing the same.
All the body work off. Tank & airbox off. The heat shield off... TPS wire runs across the frame cross member. Youl will also have to drop the undertray down. Makes getting the loom out & back in easier...
All the plugs & sockets are colour coded & different shapes so impossible to connect up wrong...There are some the same but in different areas of the bike...You've done something drasticaly wrong with the routing if you manage to connect them wrong...
Take your time & take pics lots of pic's.
Dazza2910
Post by Dazza2910 »
Cheers Mac.
I know you'd given me price for one, but found one on eBay for under £50 that is off a bike with less than 5000 miles on it, looks clean and is totally uncut and unmodified.
So worth that to get more for the bike.
Daz
Go for it!
Happy loom swapping...
Dazza2910
Post by Dazza2910 »
Is it weird that I'm kinda looking forward to changing it?
I build and repair computers all the time, so it's just a bigger version of that!
:lol: :lol:
Dazza2910 wrote: Thu May 04, 2023 10:13 am Is it weird that I'm kinda looking forward to changing it?
:lol: :lol:
:lol: :lol: :clap: :clap:
You should be fine :thumbup:
Dazza2910
Post by Dazza2910 »
After an hour so with a friend with decent electric skills and a multimeter, seems the reg/rec is causing it. So new one coming this week.
So managed to get lights/dashboard all working. Should fire up fine once the reg/rec arrives and is fitted. Might extend the ground wire to the battery instead to get better contact.
Dazza2910 wrote: Tue Jun 06, 2023 7:35 pm After an hour so with a friend with decent electric skills and a multimeter, seems the reg/rec is causing it. So new one coming this week.
Good work, fingers crossed all goes well once the new rectifier arrives :thumbup: :thumbup:
So you didn't need to change the loom after all?
Dazza2910
Post by Dazza2910 »
No. Bought one just in case but first plan was to unplug as much as possible to see if the 30A still blew. But we were testing the new starter relay that we'd put in before and that seemed fine. So started checking the things plugged in after that and the reg/rec was giving all sorts of strange readings.
So unplugged that and started putting the other fuses in one at a time and all seemed OK. Dashboard, lights, horn, etc all working. As soon as reg/rec plugged in, fuse goes.
So ordered new reg/rec and an also going to move the ground connector to the battery as it will have a better contact.
Dazza2910
Post by Dazza2910 »
It lives!! Back running again.
Happy days. 👍👍
Well done mate. 👍
Dazza2910 wrote: Wed Jun 07, 2023 6:14 am ... also going to move the ground connector to the battery as it will have a better contact.
The ground for the RR, or the main earth? Either way, what do you hope to achieve by doing that?
Grounds need to be directly to the chassis/engine.
Dazza2910
Post by Dazza2910 »
One of the bolts that holds reg/rec on had the nut threaded (and it's welded to the frame), so couldn't use that. So drilled new hole in the plate that it mounts on so r/r was at a slightly different angle. Drilled another hole for the earth so it gets a good connection while I was at it.
So it is still earthed to the frame.
Daz
Make sure you clean the paint off underneath the terminal to get a good contact.
