I used left over "special silicone" that came with my carbon adi case covers and it has held up very wellfreeridenick wrote: ↑Wed Feb 08, 2023 8:40 pm What have folks used to glue the VTR rubber seal to the CBR coil body? I never bothered but it does wiggle a bit more than I'd like. It would be better to keep water away from the plug too.
How to fit stick coils
Re: How to fit stick coils
- Pete.L
Yep!
High temp silicone all day long. Unless the gap is too sloppy between the surfaces. Then I would probably look for a bit of silicon sheet ( like what you can use for putting hot plates on) cut it to size and then stick it in place with high temp silicon
- freeridenick
Thanks folks. Some black gasket sealant I had lying around seems to have worked a treat.
