Finally got a Firestorm
Harveyz
Post by Harveyz »
Being a recent convert to twins (love my sv650 mini twin) - I fancied a Firestorm for a while and this one fell in my lap - its a 2000 bike but had a lot of mids. - 2022 body work/ clocks/ 19l tank mod - Giles rear sets +. Wilber shock and fork re-valved + MCT's. - looking forward to tinkering further - I've got some spare callipers off a 954 Fireblade are they an improvement over stock?
Re: Finally got a Firestorm
Welcome aboard :thumbup:
You have a lovely looking bike there 8)
Looking at the photo, it already has upgraded front brake calipers, not OEM stock,
welcome along sir, nice bike and as said it already has blade/cbr600 calipers fitted, you could fit a 6mm shock spacer, makes them steer more like a modern bike :thumbup:
Welcome to the club 👍
Hello and welcome to the forum :wave:
Harveyz
Post by Harveyz »
Thanks for the welcome - checked brakes and it’s also got the 954 master cylinder mod - thought the brakes seemed good- only done 26k but has the surging on steady throttle issue - after extensive reading on the forum going plug change then TPS check - if still an issue it’s off with the carbs and into the ultrasonic cleaner.
Harveyz wrote: Wed Oct 12, 2022 8:45 pm Thanks for the welcome - checked brakes and it’s also got the 954 master cylinder mod - thought the brakes seemed good- only done 26k but has the surging on steady throttle issue - after extensive reading on the forum going plug change then TPS check - if still an issue it’s off with the carbs and into the ultrasonic cleaner.
With the 954 master cylinder and brake calipers you have a very good set-up there 8)
m6speed
Post by m6speed »
benvenuto!
got the same history, my last was a SV650S, sold in 2007, and this august bought my fantastic VTR!
that's the way it has to be :thumbup:
