Fresh out of the bin zone
Lloydie2954
Post by Lloydie2954 »
Still in my leathers... Had to crack a can because Tetley isn't cutting it - binned it not be it an hour ago, I'm fine :thumbup: / so then bikes running (haha...nails these VTR's) on one pot, & I've no clutch.... * I'll sort the clutch - why am I on one pot post whoooopsie? Where should I start chaps ?? Any info or pointers would be of great help... Least it runs ay :eh:
Re: Fresh out of the bin zone
It has to be electrical or fuel, check that the plug cap is on properly. If it is, then pull the plug and check for sparks. Could be that a connection to that coil has popped off.
If you have a spark, check the carb for the affected pot.
Glad you're not any worse Lloydie,
