![](https://emoji.tapatalk-cdn.com/emoji1635.png)
![](https://emoji.tapatalk-cdn.com/emoji1303.png)
What you need is a set of nice ceramic bearings.sirch345 wrote: ↑Thu Aug 25, 2022 9:02 pm New tyre fitted to the front now (new rear was last month). Cleaned up the disc carriers while the front wheel was off the bike and spun all 16 disc bobbins after brake cleaner was applied whilst turning them at the same time, each one individually of courseWith the wheel re-fitted and the brake calipers I can now get just over 6 full revolutions from the front wheel after giving it a hard spin by hand with front mudguard removed
tony.mon wrote: ↑Thu Aug 25, 2022 10:08 pmWhat you need is a set of nice ceramic bearings.sirch345 wrote: ↑Thu Aug 25, 2022 9:02 pm New tyre fitted to the front now (new rear was last month). Cleaned up the disc carriers while the front wheel was off the bike and spun all 16 disc bobbins after brake cleaner was applied whilst turning them at the same time, each one individually of courseWith the wheel re-fitted and the brake calipers I can now get just over 6 full revolutions from the front wheel after giving it a hard spin by hand with front mudguard removed
Also, new caliper seals pull the pads back off the disc as soon as the brake is released.
