Whats in the bundle?
Faring, headlight, mirrors and screen
Seat, tail faring, cowl, rear light, indicators and tail tidy undertray
Tank with tap and fuel level sensor - may need to swap cap
Chin faring - with usual stop chips - can include brackets if required
Pyramid plastics hugger in yellow
Front mudguard - NOTE this is for the Fireblade front end fitted
Wheels with disks and tyres - Continental motion with a few 100 miles on
£550 - pm me for more photos
Not all the parts were fitted in the picture below when i first got it
viewtopic.php?t=38534
If postage is required on the below i will add the cost at request
Also have a full unpainted, unused, belly fairing with bracket - £80
Frame - small dent and bad paint - with log book - £40
Dent free tank needs paint -£40
Engine lump for spares £30 - no valves or clutch cover, probably missing a other parts. Crank pistons and gear box, flywheel (standard), electrics, - good. - crankcase has broken lugs on the chain cover
Front mudguard - yellow but needs paint - £10
Headlight - £40 - possibly 2
Standard rear undertray, been cut £15. - ideal if you dont want to hack up a good one to fit a tail tidy
Probably other stuff - located PE12 - between Peterborough and Spalding
Smokin Joe Bodywork, tank, wheels and more
Moderator: VTRDark
