AMCQ46 wrote: ↑Sat Mar 30, 2019 7:33 am
Liked the way he followed the girls in bikinis every now and then.... Bring back the 70s
And Burt Munroe there too
You've got to love the jew's harp when the girls were filmed, ha. Wouldn't happen/be allowed today. Good spot with Burt Al
, I was focusing on the Turnip Eater
No photo's I'm affraid but I've been very busy teaching myself electrics & how to wire it up. Wow, & I thought the battery box was an issue
Anyway, my original plan was to use the old messy wiring loom to find the best way to run through the bike. It needed to look clean & no modifications. I think I've done it but boy, the headstock wiring has got me sweating.
The cheap Chinese all in one clock came with a bit of a loom which would have to be spliced into the Vtr loom. The problem was that the plug connections would lay on the top yolk & be seen by everyone. Not happening.
So I removed the waterproof rubber boot from the mini loom on the cheap clock & found a 20 pin connector. Exactly the same as a 20 pin pc's power supply to a pc's motherboard connector
So I routed through my pikey-hoard to get my hands on an unwanted pc power supply to butcher for the plug & cables. Bingo. Then I had to find out what wires are required to power the individual clock instruments then connect them to the multiple plugs on the loom..
A major help has been the recognising & the purchasing of plugs that connect directy to the Honda Vtr loom.
Then it was just a simple case of identifying what wires went where. WWWW..
Two things got me last night though, I'd checked everything over 10 times but still it wouldn't turn over or beep beep the horn. Was it my wiring? Was it the rough Vtr loom's fault? A quick phone call & a chat & after I explained the situation, I was asked if I'd checked the fuses
Ha, 3 missing
Secondly the 125cc Varadero stop/start button's wiring is different. It turn's over when you apply the brake I sorted it out by moving the pins in the socket around..
I'm getting there, I felt last night was the first time I heard it breathing as it was being turned over. woohoo
