Valve clearances
Valve clearances
Hello, just checked valve clearances on rear cylinder , Exhaust 11”. and 12” . Inlet 5” and 6”, So fairly close to spec, is it worth checking the front cylinder ? Bike has done 32000, as far as I know this is the first check. Its cold in the garage and the beer is calling me . Happy christmas everyone ,
- KermitLeFrog
Re: Valve clearances
Interesting that they don't give a tolerance in the manual, or have I missed it?
You mean Haynes?
See 1.2 specifications.
Inlet 0.13 to 0.19
Exhaust 0.28 to 0.34
Metric.
Eamon, are you measuring in thou?
Inlet 0.13 to 0.19
Metric.
Page 1-7 in the factory manualKermitLeFrog wrote: ↑Mon Dec 24, 2018 5:53 pm Interesting that they don't give a tolerance in the manual, or have I missed it?
The 1st number you see is the "specification" the perfect clearance, the next numbers are the range allowed.
In that chart 1st set of numbers is metric 2nd set ( SAE) )
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Post event services
Total Rider
Yeah , exhaust 12 thou and inlet 6 thou, when I was an apprentice that was normal . After 30, 000 miles I was surprised they were so close to spec .
- KermitLeFrog
My manualE.Marquez wrote: ↑Mon Dec 24, 2018 7:34 pmPage 1-7 in the factory manualKermitLeFrog wrote: ↑Mon Dec 24, 2018 5:53 pm Interesting that they don't give a tolerance in the manual, or have I missed it?
Is that a factory manual or an after market?
I have three different factory manuals all are the same with the spec and tolerance
Post event services
Total Rider
Post event services
Total Rider
