Dot the speedo.
Cousid
Dot the speedo.
Post by Cousid »
All,
As a new firestorm owner, I need to know what speed my bike is doing when it's being very naughty, so critical to me is to know when I have reached 30mph & 70mph. The speedo is difficult to see with glasses , helmet, or streaming eyes.
I have attached a picture of a small modification that I have made, in normal riding position the dots line up perfectly,
Hope this helps someone with a steamey helmet, I am not being rude!
Bye for now, Cousid
Re: Dot the speedo.
Good work, try yellow dots they will stand out more...
Then try it with the later clocks... :lol: :lol:
viewtopic.php?f=31&t=32420&start=30#p468825
cheekykev
Re: Dot the speedo.
Post by cheekykev »
Just use a torque marker / paint pen and paint a line on the plastic outer bezel of the clock at the points you need, that's what I did when I was taking my I A M.
Because my final drive is one tooth down at the front and two teeth up at the rear, my clock is well out, and when you do the I A M you're speed has to be accurate
Plus with this method you can use what ever colour suites you best :thumbup:
Like what you do
Do what you like
Re: Dot the speedo.
You also need a Pinlock to sort out your steamy noggin protector...
Notice how I avioded mentioning your helmet...frnar frnar...
KermitLeFrog
Re: Dot the speedo.
Post by KermitLeFrog »
To get the dots lined properly up you need to be doing 70 (and 30) mph. Must be difficult sticking them on at that speed...
Re: Dot the speedo.
Just tape your sat nav on temporarily and compare to the speed display on the Speedo
That's how I calibrated my Speedo healer
Re: Dot the speedo.
KermitLeFrog wrote: Mon Dec 10, 2018 4:36 pm To get the dots lined properly up you need to be doing 70 (and 30) mph. Must be difficult sticking them on at that speed...
:lol: :thumbup: brilliant,
