Whats the standard length eye to eye 345mm or 348mm? As my nitron is 355
Thx
Sent from my SM-G950F using Tapatalk
Rear shock
Rear shock
Re: Rear shock
Think it's 348 but not sure it's been a while since I measured on. Is the Nitron on it's shortest setting on the ride height adjuster ?, mind you if 348 is right and it's at 355 thats 7mm longer, not too bad, I'd live with that but make sure there's no spacer on top of the top clevis.
Re: Rear shock
im near sure they are 345 standard. i put the penske into mine and was told to run it at 348mm by a man that knows these things
Re: Rear shock
Aren't they 366.75? I'm sure they are
- Pete.L
Rear shock
Sorry Flatty. We are talking about shock length, not what yours is worthFlatline wrote:Aren't they £366.75? I'm sure they are
Re: Rear shock
Oye! I've just seen your reply, cheeky bugger
Re: Rear shock
346mm
- Pete.L
Re: Rear shock
Flatline wrote:Oye! I've just seen your reply, cheeky bugger
