Spacer sizes
Fastdruid
Spacer sizes
Post by Fastdruid »
Could someone possibly measure the spacer that goes between the rear wheel and the brake carrier?
Part 5 / 42312-MBT-D10 as shown here:
https://www.bike-parts-honda.com/honda- ... 00/2/11534
I need one, all the breakers are only selling them with the rear axle and I'm not paying £18 for a new one when I have a lathe and can make it from a piece of bar in a few minutes!
Re: Spacer sizes
Got loads of them...Cover the postage & I'll send one...Just the one side you need yeah ?
Check your PM's...
Fiddler
Re: Spacer sizes
Post by Fiddler »
I've lost my right hand spacer as well . Looks like the same as narrow front ? I too have nice lathe ,Dean Smith And Grace
I suppose we just make it fit,!! Is the sprocket side different? That's the one I have really lost
Re: Spacer sizes
You might as well make a set of captive wheel spacers while you're there- it makes it much easier to slip the wheels back in.
Aluminium will do, but they eventually wear at the seal lip. Titanium is better.
Fiddler
Re: Spacer sizes
Post by Fiddler »
Made a rear sprocket side top hat type spacer . Get to garage . There it was bottom of parts box dirty and hiding.. Now I need to sort out SA bobbins the under SA support type not good . Creeps forwards then you have no room to manouver rear wheel in . Still now I know . R caliper in first then wheel . All back and just tighten everything up . Green wheels yellow bike .
This could be a serious manic Love affair . Of course lathe turned bobbins
