From 107 to 128
Re: From 107 to xxx
You wil find lots of filter mods going on in the following thread.
Airbox modding
And in the following:
This winter's rebuild and mods
Honda MWR Air Filters
Strangly I'm struggling to find Tonys pics on here.
Re: From 107 to xxx
I tried every possible way to get the mwr to run cleanly, but couldn't.
Withlid, without, and with and without snorkel.
Re: From 107 to xxx
tony.mon wrote: Sat Jun 16, 2018 8:56 am I tried every possible way to get the mwr to run cleanly, but couldn't.
With and without the plate too?
Re: From 107 to xxx
No, I suppose that's worth a try
Re: From 107 to 126bhp
So the initial numbers are in.
126.4bhp max
77.73 ft-lb torque max
Max power at 9000
Max torque at 7500
It's rich and reducing the mains gained both power and torque so that's the first thing to look at when it's run in fully.
StormyRob
Re: From 107 to xxx
Post by StormyRob »
That is some serious progress Nick. Really impressive must be a beast now
freeridenick wrote: Fri Jun 29, 2018 1:49 pm So the initial numbers are in.
126.4bhp max
Max power at 9000
Max torque at 7500
that is serious figures nick :clap: :clap: :clap: worth the hassle im sure..
Re: From 107 to 126
Well done that man, good numbers.
You'll soon get used to it and be looking for more.
What have you got planned next?
popkat
Re: From 107 to 126
Post by popkat »
:clap: Good numbers, got a picture of the graph ?
DOh, just saw you other thread
I think with all the engine work a slipper clutch would be really helpful and allow you to get the best out of it.
Re: From 107 to xxx
StormyRob wrote: Fri Jun 29, 2018 2:29 pm That is some serious progress Nick. Really impressive must be a beast now
I'll let you know when I've ridden it.
Re: From 107 to 126
tony.mon wrote: Fri Jun 29, 2018 6:11 pm Well done that man, good numbers.
Well. When I started this I had a goal and when the engine was running I'd achieved it. But...
Re: From 107 to 126
When things happen slowly and when one talks to folks - this great place - ideas and opportunities present themselves. And, I should have known, there's no such thing as finished.
The first thing the Dyno guy said once we'd called it a day was 'now you need to look at the suspension'. More power equals more squatting etc. I've already got The springy bits sorted but they will need setting up again for the new output.
I've got a braced swingarm ready to go in so the yolks would be something to think about at the same time. Light wheels would be great but very expensive so will probably be later or never.
Given the flattening off of the power between 9k and the limit I'm starting to think there's not enough movement of gasses to cope so finding some velocity stacks and playing with the open airbox will happen. I'm also wondering whether the exhaust is restricting this but that's mega money too.
fabiostar wrote: Fri Jun 29, 2018 5:20 pm
Well worth it mate.
popkat wrote: Fri Jun 29, 2018 6:21 pm
I'd had that thought too.
Stephan
Re: From 107 to 126
Post by Stephan »
126 is nice figure. I dont think you can get more without advanced airbox like vtr sp or mori stg 2/3 have. Open airbox is worth to try. If you can optimize afr through rev range, this is the point i would concentrate. I believe flat power on top is cause by bigger valves not corresponding to stg1 cams, so stg2 cams are only way to solve it. And with stg2 cams you will need ram air and so on ... :)
Re: From 107 to 126
nick that flattening off as you say..when i got the extra bits for mine. the parts that made a difference i could feel most without even needing a dyno to tell me was the mori downpipes up high and the ECU in the midrange...with the figures your putting out id guess your downpipes have maybe reached there max breathing wise.
i could of course be talking Shite but just from what iv felt on mine. id go get down pipes. :thumbup:
126.4bhp max
Max power at 9000
Max torque at 7500
WOW very nice 8)
Well worth the effort :clap: well done Nick,
