R/R
R/R
So I’ve been looking at the R/R posts and wanted to check the one on my 97 storm. I think it must be a newer style one as it has fins on it and looks wider than some seen. Any chance someone can take a look at the pic and see what they think? Want to start the new riding season with the usual suspects in good order.
If we don't learn from our mistakes we are destin to repeat them
Re: R/R
Can you unbolt it and take a photo of underside. It don't look like my old ones, they were proper black and without the sticker. Fingers crossed it's a replacement one already.
Don't hassle me
I'll get there at some time
Re: R/R
TourMax, after market from Japan
Re: R/R
Seems to be an import sold by Wemoto and up to the standard of later upgraded 01-05 R/R
If you google up > Tourmax regulator < it crops up on various biker forums.
If you're looking over your charging system - check all electrical connections are corrosion free and tight. A lttle silicone grease helps keep it that way esp at this time of year.
Re: R/R
Thanks Wicky, I’m going to go over the electrical system over the next few weeks but wanted to get the R/R checked out. Do you think the Tourmax is a decent one?Wicky wrote:Seems to be an import sold by Wemoto and up to the standard of later upgraded 01-05 R/R
Re: R/R
Seems acceptable - It's branded and they've been making R/Rs for more than a decade and distributed by Wemoto at a not too cheap a price (compared to cheapy chinese versions) - are you having problems?
If you want to go the whole hog and long term reliability is your priority then splash out on a FH020AA MOSFET or one of the latest SH847 Series R/R
https://www.superhawkforum.com/forums/c ... 0-a-34792/
https://www.superhawkforum.com/forums/m ... r-r-34077/
Re: R/R
I ran a Tourmax R\R for a while until I switched to a Mosfet unit.
I worked fine but still has the same issues as all diode based R\Rs in that it will fail sometime.
Re: R/R
All R\Rs should look like that on the underside. It is bare metal to transfer heat more efficiently to the sub-frame.
One thing you can do is apply some heat sink compound to the underside to make sure you have the best heat transfer possible.
Re: R/R
Makes good sense, thanks for the advice.8541Hawk wrote:All R\Rs should look like that on the underside. It is bare metal to transfer heat more efficiently to the sub-frame.
Re: R/R
Only the cheap pattern MOSFET ones are metal on the back...\all real Shindengen R/Rs are potted epoxy in a metal shell, you will only see epoxy on the back side. many times the bike OEM will sandwich an aluminum plate (heat Sink) between the RR and frame... but the RR it self is not metal on the back, unless its a crap copy.
This was all confirmed with Shindengen ( I called, and was transfered to a Tech person that spoke better English than I do, educated in the west it seems is common, then back home to work)
EDIT: NOTE The epoxy back from Shindengen vice metal...Im speaking about the SH and FH series RR's.. I do not know if that same info applies to ALL Shindengen or other brand RR's, but I do know it applies to the FH and newer SH series..Metal back NOT real... epoxy back, might be real..I have bought a few used ones now that were epoxy back and looked right in the Ebay ad, but once in my hands, suspect so they hit the scrap metal pile.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Post event services
Total Rider
