Engine rebuild - cylinder re-sleeve
Chris58
Re: Engine rebuild - cylinder re-sleeve
Post by Chris58 »
mik_str wrote: Mon Feb 05, 2018 12:46 am
Chris58 wrote: Mon Feb 05, 2018 12:39 am here in Canada.
Canada? whereabouts brother? I'm in Montreal...
Im in Norwood/Peterborough.. about 6 hrs west of you
mik_str
Post by mik_str »
gotcha... drove through there lots (Hwy 7)
Chris58
Post by Chris58 »
E.Marquez wrote: Mon Feb 05, 2018 12:55 am
Chris58 wrote: Mon Feb 05, 2018 12:39 am I did contact 2 companies about nikasil after the machine shop incident. Both said it doesnt adhere to cast iron liners. Haven't looked into it much since..
Not saying it cant be done, but I couldnt find anyone who does it on iron here in Canada.
In the US and Canada Millennium Technologies LLC
1404 Pilgrim Road, Plymouth WI 53073
phone: (920) 893-5595
fax: (920) 893-4830
In Canada:
Please contact Fast Enterprises
at 204-895-1727.
Q.Can you plate cast iron?
A. We can plate many materials, cast iron included. By plating cast iron the cylinder will have all the benefits of NSC except the heat transfer. These benefits include 10 times better wear resistance, more horsepower, and better ring seal.
Thanks E.Marquez, Great info there. Not a lot info about that online.
I was informed that chrome is an option to, but not practical due to price, finding somewhere that does it well, and proper rings etc.. apparently chrome bore was common back in the 70s/80s
Stephan
Post by Stephan »
In case of chrome cylinders, will you have suitable rings too? Before you mentioned sp rings designed for nikasil, i believe these can be used in cast iron sleeves.
Another point is for different pin diameter on other pistons. If diameter is smaller than on vtr rods, you can make new bushings. Pricey, but not so wild idea in your situation.
If you are considering new pistons, custom made from cp pistons is an option, rings included. I did it this way.
what size are Honda Dominator pistons??
Chris58
Post by Chris58 »
Stephan wrote: Mon Feb 05, 2018 8:50 pm In case of chrome cylinders, will you have suitable rings too? Before you mentioned sp rings designed for nikasil, i believe these can be used in cast iron sleeves.
I am for sure going to get custom pistons, still waiting to hear back from JE..
Its just interesting hearing others opinions on possible solutions. I belive with chrome bore, you would use cast iron rings..
Stephan
Post by Stephan »
Ok, but not sure if you can buy the set. It is hard to find some reliable info, so just for curiosity, question 12
http://www.wiseco.com/FAQs.aspx
mik_str
Post by mik_str »
sent you a PM Chris...
Chris58
Post by Chris58 »
mik_str wrote: Mon Feb 05, 2018 11:09 pm sent you a PM Chris...
Got the PM, need a minimum number of posts to respond.
Sounds good to me though. pm me a way to contact you, Ill let you know details.
Chris58
Post by Chris58 »
Stephan wrote: Mon Feb 05, 2018 10:55 pm Ok, but not sure if you can buy the set. It is hard to find some reliable info, so just for curiosity, question 12
Good info there, looks like the same rings for a cast bore are also used with nikasil from what they said.
There are companies that make custom cast iron rings in the case of a chrome bore, its hard to find info about why only cast iron rings are used with chrome..
http://adpistonring.com/cast-iron-piston-rings.html
mik_str
Post by mik_str »
Chris58 wrote: Tue Feb 06, 2018 1:48 am
another PM for you
Chris58
Post by Chris58 »
Got a response from JE. They have no problem with supplying 99mm pistons with, rings, pins, and clips.
There was no minimum order on those either, I just emailed saying I want part#149139(vtr1000f 11.5:1) but in OS to 99mm..
They said no problem.
Stephan
Post by Stephan »
Great news, hope you will go straight after that.
Chris58
Post by Chris58 »
Stephan wrote: Tue Feb 06, 2018 6:31 am Great news, hope you will go straight after that.
Thanks Stephan, I hope so.
Chris58
Post by Chris58 »
Received JE custom 99mm 11.5:1 pistons today, getting block bored next week.
I dealt with a guy named Bryant.. I would highly recommend dealing with him.
Heres a few pictures with a bit of useful info. Notice on the spec sheet it has a job # for reordering...
