VTRDark wrote: ↑Sat Feb 03, 2018 12:13 am
No...not heat wrap like the stuff the US wrap around pipes. A plate coming out from the frame wrapping over the pipes where your inside leg will be. Put some reflective heat shield on the inside of the plate too. It will at least deflect some of the rising heat away and stop burns. The bottom (rear) pipe maybe more of an issue. ou will most likely need some refective heat shielding under the seat too.
I did think about fitting heat shielding a while back, something similar to what genuine flat trackers have.
Now I think it's a certainty, I think that things like large heat shields can go ugly/wrong very quickly too.
I was thinking of making a plug mould from two bits of rain guttering. Reduce the diameter of each length at one end with heat & screw it to some shaped bits of 60mm round wood.
Then screw the two lengths together parallel'ish with wood in-between.
It doesn't make sense typing it, but I'm hoping to achieve a guard that looks like two megaphones together.
It's been a long day, sorry
