Moriwaki carbs for sale on jauce.com
- StormyRob
Re: Moriwaki carbs for sale on jauce.com
I hoped you were!
stop all this talk about porn please
Well they are back..... listing from today.....
https://www.jauce.com/auction/j469661512
yeah, they've been back for a while now already; not sure what the story is there... anyone know if there are other differences (from OEM units) apart from them being made of magnesium (which should being an obvious weight saving)?
As far as I have heard that is the only real difference and that Mori had 3 different needle configurations.
Though like I stated before there is some kind of issue with the front carb on this set as the pic down the intakes shows the slide stuck half way open.
- freeridenick
I've had a long conversation with a contact I was put on to inJapan and ended up backing out. Reviews for the seller suggested OEM carbs would arrive. Could well be that others are worried too.
freeridenick wrote: ↑Sat Jan 27, 2018 8:31 amI've had a long conversation with a contact I was put on to inJapan and ended up backing out. Reviews for the seller suggested OEM carbs would arrive. Could well be that others are worried too.
you would be well pissed if you opened the box and found standard carbs
amen, paying that price for OEM carbs would be, well, criminalfabiostar wrote: ↑Sun Jan 28, 2018 8:53 amfreeridenick wrote: ↑Sat Jan 27, 2018 8:31 amI've had a long conversation with a contact I was put on to inJapan and ended up backing out. Reviews for the seller suggested OEM carbs would arrive. Could well be that others are worried too.
