Quick action throttle.
Does the HRC throttle tube do the same job as the domino ones that are around £120-150?
And if so is this the correct item? https://rover.ebay.com/rover/0/0/0?mpre ... 0752530363
Thanks.
Thanks.
- freeridenick
Re: Quick action throttle.
The HRC one is 1/6th turn. I think the Domino ones are 1/4. So yes and no.
There are 1/4 turn tubes available for peanuts so don't waste money on a flash after market one. The SP tube is a 1/4 turn I think.
Thanks for that mate do you know if that listing is the correct part I need?
Domino come with three different options for the cable spool, the first a bit quicker than std, the Middle one quite a lot quicker than std and the largest is like a light switch and really only suitable for track use.
You have to factor in new cables as well....
I fitted one to the sp2 recently. Middle option works well for me. I used the xml and universal cable set, check with them before ordering as I don't know if that will also work on a Storm.
HRC tube works very well (been running mine for well over 5 years now) but it will take you pretty well right to the end of your cable adjustment range. They can be had quite cheaply on eBay
Thanks for reply’s I’ve ordered HRC tube see how that goes.
people have used yamaha R6 tubes?? tho which year im not 100% sure on.
You guys do know that stock is 1\4 turn?
I had to go out to the garage to look as I was confused.
My '97 is a 1/4 twist, I thought it was more..
Everyday a school day.
Don't hassle me
I'll get there at some time
I believe that they all come with a 1\4 turn throttle tube stock
ah right ..... so do we have a number for the correct 6th turn one?? i have one on the yellow bike but for the life of me cant rem which one i bought for it
There is a HRC tube that some folks use though I don't have that p\n
The other option that has been used is the RC45 tube though I'm not sure if it is 1\5 or 1\6 turn. The P\N for that is 53140-MR7-000
RC45 is 1/5 turn IIRC. For the HRC unit, just do a search on eBay, they are virtually always avail there...
IIRC the RC45 is 1/5 of a turn, and the HRC is 1/6 of a turn.
According to KarlosVTR (link below) the part number for the HRC throttle tube is:- 53141-MT7-000
viewtopic.php?f=9&t=15303&start=15
