blue smoke from both the mufflers
Big_Jim59
Re: blue smoke from both the mufflers
Post by Big_Jim59 »
tastethefloor wrote: Tue Nov 21, 2017 8:08 am how is possible to have both cyl rings and bores worn? the bike run well
In my opinion I have got more likely a valve problem, the smoke appear for a while on acc and then disappear
now the problem is which head need to be serviced... :?:
Since the problem seems to appear on hard acceleration I would guess that you have worn intake valve guides and bad valve guide seals. The giant suction created by those big pistons will pull oil down a marginal guide in a hurry.
tastethefloor
Post by tastethefloor »
I got another engine for that bike with a lot much less km, I was thinking in a swap..the amount of work is quite the same
fulviogsx
Post by fulviogsx »
tastethefloor wrote: Tue Nov 21, 2017 4:20 pm I got another engine for that bike with a lot much less km, I was thinking in a swap..the amount of work is quite the same
Best option is swap ...and later repair the hold one
tastethefloor
Fulvio ma sei italiano?
fulviogsx
Post by fulviogsx »
tastethefloor wrote: Tue Nov 21, 2017 4:58 pm Fulvio ma sei italiano?
Si certo :)
Ere, they’ve gone all continental on us!!!!! :lol:
Big_Jim59
Post by Big_Jim59 »
Having done both I would say that pulling both heads is a piece of cake compared to swapping engines.
tastethefloor
Big_Jim59 wrote: Wed Nov 22, 2017 2:51 am
did u replace the head gasket with a new one?
fulviogsx
Post by fulviogsx »
tastethefloor wrote: Wed Nov 22, 2017 12:23 pm
This is a good question.depends on your pocket.On an 80000 km engine you can proceed in two ways:
1)Dismantle and refurbish both two heads:guides,seals and machining and new gaskets.(and check/eventually refurbish rings and pistons )
2)otherwise cheap repair:without service the other head,,changing only the valve seals or eventually one or two guides involved.in this case is in my opinion a no sense change the head gaskets.
All the other ways to proceed (little less than 1),little more than 2))are in a medium terme economically ‎disadvantageous
I agree with Jim, but as others keep saying do a compression test first would be my advice too,
tastethefloor
fulviogsx wrote: Wed Nov 22, 2017 12:48 pm
Fulvio il cilindro posteriore sembra ok, non mi sembra il caso di aprirlo se è a posto
ciao
Ere Kev. They done it again.
I saw that Al. Makes me feel all multi cultural innit! :lol:
tastethefloor
ehhh came on..
New head gaskets every time they are disturbed for me.
The Honda gaskets are coated with a sealer coating and it breaks up as soon asyou pull the head off.
You could try a liquid sealer (silicon, hematite etc) but you run the risk of clogging an oilway or coolant gallery, which could complete wreck your engine.
Reusing will possibly work but is, I think, a false economy.
